1 - 2 of 2 Posts
Ive got a Zakk set (81/85), and im trying to add a PA2 (booster).
It would be the 81, 85, two volumes, and the PA2 switch. The diagrams that came with the booster, has a similar diagram but requires a "master tone", which is different from the tone's that come with the ZW set. I dont want to add a tone. I never use the tone knobs.
Anyone know how to bypass the tone, and just wire the two pickups, the boost, two volume pots and the input jack? Ive got an EMG buss to tie it all in. Its all solderless by the way
You should be able to use the lead coming from your switch that goes to your input jack.
if you look at the strat diagram here
http://www.emgpickups.com/media/productfile/E/M/EMG-PA-2_r0230-0016D.pdf
you can see that the white wire coming from the volume pot goes in to the PA2 . In your case the white wire should come from your pickup switch and go to the same place on the PA2. Everything else should be the same.
1 - 2 of 2 Posts
