Can you use Fender Amps for Heavy Metal if you use a high gain distortion pedal?
W Wayne27 · Registered Joined Jun 1, 2018 · 25 Posts Discussion Starter · #1 · Jul 27, 2018 Only show this user Can you use Fender Amps for Heavy Metal if you use a high gain distortion pedal?
S sepulchrave · Registered Joined Apr 26, 2018 · 547 Posts #2 · Jul 27, 2018 Only show this user Wayne27 said: Can you use Fender Amps for Heavy Metal if you use a high gain distortion pedal? Click to expand... You can use any amp for metal if the pedal is doing the distortion because you set the amp clean for it.
