1 - 20 of 21 Posts
Just recently i got an RG 320 FM (fireburst finish) and i already know im going to modify this baby like krazy. Ok now im sure im gonna get an EMG 81 Active bridge pickup installed, add some inlays in the fretboard, and finally get the Edge 3 Trem replaced by an original Floyd Rose trem. Here's the deal, I dont know if the Edge 3 cavity in the guitar is the right size for the FR trem. Does any one know if this cavity is compatable with a FR trem? Because all i can find posts on are the Edge Pro's, Edge Lo Pro's, and ZR trems; but i cant find anything about the Floyd Rose trem conversion. So if you know anything can you please post a reply here. Please give me some info if you can.
Thanx ^_^x
You should now expect a flurry of flaming posts that claim this has been discussed to death, and to "search the forums", etc., all because people won't take the two seconds to read that you're talking about an Edge 3 (new trem for 2005), not an Edge Pro II, or an Edge Pro III (doesn't even exist!).
There is one thread here on swapping an original Edge into an Edge 3 cavity, but there was no conclusion:
http://www.jemsite.com/forums/showthread.php?t=35865
Anyway, what you could do is remove the trem and measure all the dimensions of the cavity, then compare with the measurements on the Floyd Rose website. That's probably your best bet.
Have fun,
-John
Have fun,
-John
Yeah, it appears he did search already too...
as for the answer, all i can say is it may require routing, or may be routed too far so it would be a pain. An Edge Pro might be the best way to go because they are kind of big, so too much routing should not be a problem.
Is the Edge 3 a budget trem? I am not familiar with it...
Discussion Starter · #6 ·
Hey wow thanx you guys for taking the time to post some things on for me! Ok well last night one of my small "E" strings busted on my new fire burst RG 320 FM (it may be a 2004 or 2005 im not 100% sure). and i figured it was a perfect opportunity to investigate the Edge 3 trem for myself!. alrighty then; well when you first feel the edge 3 its rather short and low for a locking bridge so its a very small body cavity with a ton of space for xtreme pull ups and dive bombs. the strings can also now be installed with or without the ball end on them and this takes less time to restring and no little pieces fall out when you do this either. as for the effectivness of this the tuning stability, lets just put it this way, even on the most insane dive and pull the little bugger still pops back into tune! people on this website have constantly persecuted the edge 3 for being unsuperior to the Lo Pro and the Edge Pro bridges. But by the amount of quality this little baby has for the price it is enough to measure up tho the name Ibanez. However i am still going to replace this bridge with a floyd rose because they move more fluid like and clean. ohh and also i plan to add some personal fabrication onto "Exodus" (its what i named my guitar lol) like abalone shell inlays in the neck and maybe even the body. so hey, if there is something you guys wanna add please do cause i need all the info i can get ok.
Thanx
-John L
That sounds like an EDGE Pro II and I highly doubt you can drop a floyd directly into the cavity...
The newer models RG's from 2xx and 3xx all have a new trem which seems larger and quite similar to a lo pro edge trem, so you could probably retrofit an ofr into one of those allthough they dont have the keep the ball end thing the EPII's and EP's do...
Good luck anyways............
Ozz
Discussion Starter · #8 ·
Today i went to the floyd rose website and got the dimensions for the Original FR trem. Now all i have to do is measure my cavity on my RG and once and for all find out if a FR trem can be swapped in a Edge 3 cavity. However i would honestly go with the ZR trem on the S series but the dont fit on the edge 3 cavity. I love those trems for any situation that needs a durable and reliable trem. Any way i just put my some new Hybrid Slinky strings on my RG and let me just say this, it took almost 3 hours for some one like me (who had never tinkered with a locking bridge and nut configuration) to find out how to stablize the trem at neutral and drop all of my strings down a whole step cause i just love playin tuned way low for lots of metal and Alexi Laiho licks, lol. Ok and if the stupid FR doesnt fit right, does anyone know what other locking trem will fit in an edge 3 cavity cause i really wanna get one. hey and thanx all of you who took the time post a reply.
laters
-John L
Ozz
If it's an Edge Pro 2, he could put an Edge Pro in?
Discussion Starter · #11 ·
Ok guys, i cant find a single pic of my exact guitar on the net and when i changed the strings i wasnt able to really to date my guitar or its trem!!! the only thing i found were the small words "made in korea" and the model number is: C 03081554. well i went on the ibanez websit to try and find it, but to no avail. It has a fire burst finish and im pretty sure the pickups aren't INF style cause they have shiny pole peices unlike the 2005 with the INF black dull pole peices so now im convinced its a 2004 but im not sure what type of trem it has. Let me describe it ok; it is quite small for a locking bridge, the cavity is very deep and easy to pull back into, the fine tunners are rather short as well and it does have those little ball holders in it for the strings. yeah that about covers it. so does anyone have any sort of clue as to what type of trem it has cause there are so many different types of edge trems and they are really starting to get me confused. it also would be really awsome if someone took the time to breifly describe the differences in them. ohh and also does anyone know what kind of pickups came standard with this sort of guitar in 2004? I think they may be wussy Powersound pickups but im not sure. im gonna get an EMG 81 active still to replace the bridge and i think that i may get a DiMarzio Super 2 neck pickup too but just outta robot curiosity i wanted to know what the originals are. Oh and one more thing, i heard that the ZR trems are even smoother than an Edge Pro. is this true, like which trem is better outta those two?
Thanx
-Solo John-
Thanx
-Solo John-
The ZR trem is a ball bearing trem while the Edge Pro is knife edge based. Both trems equally good, it all comes down to personal preference in the end. Can you do a pic of your guitar?
Regards
André
I can tell you for a fact that your guitar doesn't have an Edge III on it; sounds more like it has an Edge Pro II and was made between 2003-2004. From personal experience, I would say that the ZR trem is great on tuning stability but it's definitely not as "fluid" as an Edge Pro just because it's not fully floating. Also, you'd need a HELL OF A LOT OF ROUTING to get a ZR trem into an RG body. You'd probably have to fill in the entire cavity and then recut it. But if you're already going to go the routing route, then I'd suggest checking out a Floyd Rose Speedloader trem. They have the easiest freakin' string changes around AND it has the little thing on it you turn to make it stop floating.
Discussion Starter · #15 ·
Re: Floyd Rose into an Edge Pro II cavity???
Ok now i did some research and i think i can be confident enough to say it is an Edge Pro II trem from korea. However i still am not sure what sort of trem will fit in the cavity!
Hmm but you guys say that maybe a Speed Loader trem will work ? well what about the fit, cause i really dont wanna route the guts outta my guitar, i just need to find a reliable trem that can replace the Edge II i have. And i was wondering if it is possible to drop the tuning at all on those speed loaders cause they are double ball strings arent they?
Anyway last night i busted another string doing suicide pull ups and dive bombs, so i took all the strings out and pretty much gave my guitar an enema. well the real reason i took off the neck and bridge was to roll my frets down on the side cause they were kinda rough unlike the prestige necks. so anyway when i get home today, i am gonna see if i cant do some custom art fabrication to it with out getting yelled at by my parents (sweet jesus! they think that i will destroy every guitar i get my hands on untill recently when i showed them how good i was at fabrication like inlays and stuff. now they trust me a bit more i guess). well i need to get the new EMG installed so i think i will leave the trem and strings off for a while.
so if you guys can find any more stuff about the edge pro II trem i would like to hear it ok. thanx.
Solo John-
Discussion Starter · #19 ·
yeah you guys are right, it is a really nice little trem but the only way i would keep it would be if there was a higher trem bar i could put on it. the one its got right now really pisses me off because its just to damn close to the bridge! and because of this, it is really difficult to do palm mutes and speed picking. is there like some other type of arm at least that i could slap on it instead of replacing the entire thing? like is it possible to switch it with a ZR trem bar or a FR trem bar?
thanx
-DoomsdayChild-
thanx
-DoomsdayChild-
You can raise the bar height by removing the rear cover and turning in height adjustment screw. Not sure if that would help your problem though as its limited it adjustment.Also-the bars a not interchangable.I cant quite understand why the bar is in your way as compared to other IBZ trem bars....FWIW- Sometimes I bend the bar to my liking.Before you do that however its important to have spares!Because I couldnt find the bar for sale I went to Guitar Center and the salesperson there gave me 3 of them no charge! HTH-Bob
1 - 20 of 21 Posts
