1 - 3 of 3 Posts
Any one know if the Licensed floyd in the agile interceptor can be replaced with one of these bad boys?
Also is this bridge look like its low profile? If so then gonna be sweet.
Would an ibanez lo-trs 7 work?? Where are these found ??
Thanks
If low profile is important to you, I suggest you check these units.
http://www.wammiworld.com/kahler systems.html
Now I haven't seen or touched 7-string guitar equipped with this kind of tremolo, but it sure looks low profile :D
If you don't want to swap your blade kind of floyd on that guitar to rolling kahler, I suggest you get your current bridge measured and you can compare the dimensions to those given at warmoth's site. But as these are both Floyd licensed bridges, they might be even made in the same factory, so there is no reason to swap a bridge to a exactly the same one, unless your current one is damaged.
Discussion Starter · #3 ·
the kahlers are kind of out of the picture as Ihave a floyd/blade type trem. The only reason why i would change the trem wouldbe to get the lower profile in the new one.
1 - 3 of 3 Posts
