1 - 1 of 1 Posts
It's in good condition. There are a few scratches on the sides from being bumped into walls and things like that, but nothing really noticeable and definitely nothing that affects the performance of the amp. I've had this amp for a couple of years now and have never had any problems with it. It still has the original tubes.
Here are the specs from peavey:
* 50 watts (rms) into 16 ohms
* Two 6L6GC and three 12AX7 tubes
* Two independent footswitchable channels
* Separate EQ for each channel
* Footswitchable gain/volume boost on lead channel
* External speaker capability
* 12 inch ValveKing® speaker
* Reverb with level control
* Buffered effects loop
* Resonance switch for "tight or loose" cabinet response
* Patented Texture™ variable Class A simulation control
* Footswitch not included
* Weight Unpacked: 41.00 lb(18.597 kg)
* Weight Packed: 46.00 lb(20.865 kg)
* Width Packed: 14.25"(36.195 cm)
* Depth Packed: 25.12"(63.8048 cm)
* Height Packed: 22"(55.88 cm)
and here are some pics:
http://tinypic.com/r/22avsm/6
http://tinypic.com/r/2qt8j89/6
Asking for $350
Right now I'm only interested in a local pickup. If you live just about anywhere in Kansas or Northern Oklahoma I can probably meet you somewhere. I live in Wichita KS on the weekends and I'm in Ark City on the weekdays.
Post here, PM me, or email [email protected]
1 - 1 of 1 Posts
