Here's my midi/signal path:
FCB1010 > JMP-1 > G-Major (then out to Marshall 8008 poweramp)
I want to use the FCB1010 to send program changes to the JMP-1 and G-Major simultaneously. For example: FCB pedal 01 selects preset 23 on the JMP-1 and preset 07 on the G-Major. FCB pedal 02 selects preset 17 on the JMP-1 and preset 49 on the G-Major etc.
I've programmed the FCB1010 to send program changes to the JMP-1, no problem there. I'm trying to map the PC changes thru the JMP-1 to the G-Major, big problem there.
The G-Major is a recent replacement for a Quadraverb, in that set up I used the JMP-1 output mapping to send program changes to the Quadraverb and had no problem.
I can't get the GMajor to accept the program changes I map thru the JMP-1. It changes programs, but it changes to the corresponding JMP-1 preset. example: FCB pedal 01 selects JMP-1 preset 23 as desired but G-Major also changes to preset 23 rather than 17 as mapped.
I assume I have something in the G-Major Midi menu set incorrectly, just don't know what. I've tried different settings but no luck...
I'd appreciate any help you can give, thanks in advance,
john
john
