1 - 5 of 5 Posts
I have a Godin SD with HSS and the humbucker has 4 mounting screws going into the pickup, two on each side, (which the one isntalled has the matching four holes). I am trying to mount my new seymour duncan dimebucker pickup but it only has 2 holes, one on each side, that are centered so it does not line up with the holes in my pickguard.
How am I supposed to install it?
If you are good with metal fabrication you could attach a tab of aluminum or steel to the PU mounting holes that will extend out to mount onto the pickup screw holes. I see you having to rivet the tab onto the pickup though and that isn't something most people have tools to be able to do.
Discussion Starter · #5 ·
Another option may be to mount the pickups directly to the body.
Yeah this was suggested over at harmony central as well. I beleive this is what I will try doing tonight. Trick is going to get it lined up correctly. Will lose adjustment capability tho...
1 - 5 of 5 Posts
