1 - 9 of 9 Posts
I´ve bought a Ground Control Pro from a US dealer I´m waiting for. The power supply needed in the US is 110VAC-9VAC 500 mA 60Hz. I have a power supply 240VAC-9VAC 500 mA 50Hz. Is the Ground Control Pro ready to work at 50Hz?
Thanks
I know mA if you are below the value you need than it's fine. But you are above in Hz. Not sure if that's a factor or not.
With mA if the power supply is above the value you need it's fine, not less. ;)
eg. pedal needs 200mA, you have a 500mA you are fine
pedal needs 300mA, you have a 200mA not fine
Discussion Starter · #6 ·
Thats why I asked! I different Hz!
I asked Voodoo lab and the GCP works at 50 or 60Hz, no problem, so those who live in Europe don´t worry about that. The only issue is the tip of the power supply has to be wider that most pedals (i.e. boss pedals)
Do you have a chain based electronics store in Spain? If so they probably sell variable power AC adapters with a range of plug options. Find one of those and you should be right.
1 - 9 of 9 Posts
