I got a grgr221pa-aqb gio recently, always wanted to try an Ibanez and this seemed like a good versatile entry option. I really like it, except for the huge amount of hum it produces when run through amplification.
I use VSTs and realize that some noise is unavoidable, and know how to use noise gates and so on, but the noise from this guitar makes it unplayable. I run other guitars through the same recording equipment and the noise is nowhere near as bad as from the Ibanez.
I have tried checking for grouding issues using a multi meter (checked continuity between all metal, also checked resistance between solder points) and found nothing that would indicate bad ground or cold joints but the guitar sounds like the grounding is bad. I´m kind of a noob when it comes to these sort of things though, so i came here looking for tips. How should i go about diagnosing this? Any help would be appriciated, and if any further info is needed, I would be happy to provide it.
