1 - 3 of 3 Posts
1986 Ibanez DX series Roadstar 2 RG440PB - HSS - 5 position switch 1 volume, I coil tapping Push Pull Tone.
Pix 1st the guitar, 2nd the wiring diagram I have.
https://flic.kr/p/2143372698
https://flic.kr/p/2235552321
NooB with all this stuff, this is like my fourth ever pickup job. I replaced the Bridge Humbucker and now the middle single coil pickup doesn't work.
The humbucker and coil tap works perfect. The Neck single coil works fine. The center (#3) position on the 5-position switch is dead. Nothing. In position #4 which I think is supposed to be the bridge Humbucker + Middle Single coil only has the Humbucker. Oddly, position #2, which I think is the two single coils together, does get something out of the middle position single coil???? I can't figure this out! ** The wireing diagram is NOT the same as how this was originally wired. I can detail the deviations if anyone thinks that will provide value. **
I started by writing out a diagram of the current wiring. All 2-wire pickups. I noted the differences with the diagram. But everything always worked perfectly so I merely noted the differences and didn't worry about it. The new dimarzio pickup is a 4-wire so I made an educated guess consistent with my previous pickup changes and used the dimarzio diagrams for push pull coil taps as reference. After I was done I tested and the new pickup worked perfect. Went through the other positions and the middle pickup wasn't working. ****. I checked the wiring again. Double ****! I noticed the "white" wire to the #2 tab on the 5-position switch had come off. I resoldered, clearly that was the problem. Still doesn't work. I checked for shorts. Taped up the ground wires. I removed all the solder from the tab. Cleaned the tab with wire brush. Stripped and retinned the wire. Reconnected. Still no good. I checked for a possible short. Still no good. The odd thing is I seem to get some weak activity when both single coils are selected. I never tested that before, so I don't know if in this position the middle pickup should be about half strength compared to the neck pickup. Not sure where to go from here, other than have a pro fix my mess? I mostly only play on the bridge and neck pickups anyway, so I could live with this for a while, but obviously I want my newly refurbished old girl in tip top.
Advice???
Discussion Starter · #2 ·
So I checked out my radius which though wired differently is HSS as well. I notice that on several positions where a pickup is not selected tapping on the poles with a screw driver does give a slight sound much lower (obviously) than the "on" pickup. So I guess when I tap the poles of the other guitar and hear something it doesn't mean much. But it is still interesting that when that middle pickup is selected it is completely dead, and in position two it makes some low noise when tapped. I'm not sure that this rules anything in or out, but I just thought I would give as much info as I can.
1 - 3 of 3 Posts
