1 - 5 of 5 Posts
Hi All
I have an old RG body with an AANJ of an unknown model, and I want to buy a neck for it.
The heel of the neck cavity runs straight into the neck pickup cavity - a humbucker cavity.
I am correct in thinking that I am therefore looking for an AANJ Wizard II 22 fret neck for this body to fit?
24 fret would have the extension board run unto the pickup cavity I assume?
Thanks for any help!
Discussion Starter · #3 ·
aanj necks don't have a fretboard extension, they have only a small amt of overhang. The old neck joints had overhand, that is why the jems were made with top 4 frets scalloped.
Ah, of course!
So does that mean the actual neck length changes for AANJ necks between 22 and 24 fret?
If so, looks like I will need to do some measuring!
If I have got that correct, does anyone have the neck length measurements for a 22 fret vs 24 fret?
Both should be 25.5 inches, I think most rgs have 24 frets. I'm not sure which Ibanez models had 22 but I don't think any rgs did.
The aanj and original joint changed only by cutting out more from the pickup cavity. On aanj your pickup cavity will have a hole to your neck joint. I believe original has a small piece of wood between them. The neck lengths are the same to keep the physics of the instrument correct.
Discussion Starter · #5 ·
ok, so if that is the case then pretty much any AANJ RG Ibanez neck would fit any Ibanez RG body?
Thanks for the help so far!
1 - 5 of 5 Posts
