1 - 7 of 7 Posts
Hi guys... I did a search for this and didn't find an answer..
I have this:
-Dimarzio Evolution set (bridge,middle and neck)
-Dimarzio EP1112 Multipole 5 way Switch
-Dimarzio 500K volume pot
-Gibson 500K push pull tone pot
I need a diagram for the best way to connect this all together so I was thinking about something like this:
Push Pull Down : Normal HSH configuration
Push pull Up: Try to get as close as possible to an SSS configuration ( as far as i have split humbuckers on positions 1 and 5 it's ok for me but if it's possible to have other cool combos on positions 2,3 and 4 it would be really awesome)
Thanks in Advance
the dimarzio website list loads of wiring options under the support tab.
not sure if that would give you the exact wiring you need but they do list a good few options.
Discussion Starter · #3 ·
Thanks for your answer... I already looked on dimarzio site and only found diagrams for either dp1112 or push pull... there's no diagram for this two together
its funny but i used to have that same setup/configuration in one of my guitars but i never wrote it down before i changed it,i do remember there were many options though using a multipole and a push/pull tone knob.
Discussion Starter · #7 ·
Thanks for your answers... right now I think I will use Tosin Abasi diagram found on Dimarzio site the only thing I don't like is the lack of a middle pickup sound on position 3
1 - 7 of 7 Posts
