1 - 11 of 11 Posts
I bought this guitar yesterday. It's made in Japan in 1990. The guy who sold me told me that he put some Dimarzio in bridge but he "don't remeber" what is model... Guitar is amazing! Neck is great, frets are fine and Floyd is work great. I don't have a problem with "out of tune" at all. All in all, I am happy with this guitar!
BUT, how to know what Dimarzio I have? Do I have to remove it to see it or do I have another way?
Here is pics:
Q2: What is sound difference between V1-V2 and V7-V8 hums on this guitar?
This is my first Ibanez, so apologize for my ignorance.
Thanks!!!
Congratulations on the RG550! Looks like a great player guitar, worn in and ready to rock.
From the looks of the pickup bobbins, it's most likely a Dimarzio Tone Zone, but there are less popular models with the same bobbins.
If you want to know for sure, yes, you have to take off the strings, and then unscrew the pick guard, and just look at the underside of the bridge pickup.
You don't have to remove the pickup at all, just open the guitar up and take a look. It should either have a sticker, or a stamp into the under side of the pickup that tells you the model number.
From there just go to the Dimarzio site and see which model you have by matching the number (Tone Zone is DP 155).
As for the difference between the different V humbucker pickups (Ibanez version of the Dimarzio) they are made specifically for neck and bridge sounds, so they don't sound the same.
I usually always replace my stock V pickups in all the early RG models I have, usually with Dimarzios (My favorite is the Tone Zone or PAF Pro, but I have other models in other guitars so I can get different sounds from all of them). The V's don't sound all that bad, but you can get a wider variety of sounds by using different models of Dimarzios. More versatile.
Enjoy your first Ibanez RG, you got one of the best ones! (in my opinion:))
I have V1, S1, V2 in mine and I really like the way they sound, they're warmer than the V7, S1, V8 combo I have in another Ibby.
I think of V1, V2 as more an early/mid 80's brown sound whereas V7, V8 is a bit more hair metal.
Shortcut to identifying your DiMarzio is to measure DC resistance, you should find a bridge 'bucker which matches that DCR fairly easily, you don't need to any dismantling, just flip the switch into bridge, make sure the volume and tone are up full, plug a patch lead in and measure across the other end.
Discussion Starter · #4 ·
Thank you guys!
I just do it what did you say and I have DP160 or how the google say it's Norton, not Air Norton, just Norton:?
This hum have a highier output than V1. Sound is ok, but I must try guitar on some serious amp because I'm currently using Boss Katana 100W and Line 6 Helix. When I say serious, I mean some valve beasts like Mesa, JCM900 etc.
Since I mostly play prog-rock music and instrumental music (D.Theater, Vai, J.S, Tony Macalpine...) maybe I'll sell this hum and buy some other Dimarzio or Dimarzios. Only thing that I hate about Dimarzios is a 1000000000 models!
But hey, for now I will enjoy in my first Ibanez and with such thin neck playing was never easier, guys, that is a great feeling.:cool: Who knows, maybe Norton is not such a bad solution at the end.
Cheers!
Complete opposite comparison bro. The V7-V8s were designed in the 90s for that era of music, but they put the magnets in the wrong pickups. The V1-V2 were made in the 80s and match the 80s sound MUCH better with their warmth. Listen to Dokken or WASP from that era: rich, creamy tones. The V1/V2 set is VERY much a PAF-like pup designed for the 80s sounds, whereas the V7/V8 are designed for the more modern-ish sounds of the late 90s.
The V1/V2 set is one of the best in house set of pups you'll find from ibanez imo. I think the only set that competes is the V5 set found on 84-85 Destroyers, or possibly the 90s quantam pups (The V1/V2 definitely sound better than the 90s quantams though).
Are you kidding me? You just repeated exactly what I said and then told me to listen to music I started listening to 40 years ago!
I didnt repeat anything. The V7/V8 were designed with 90s rock music in mind (they were released in the 90s you know), the V1/V2 with 80s metal. You said the V7/V8 were for mid/late 80s brown sound, which is NOT what I said.
You listened to 80s metal, I had it everywhere around me. I went to the same high school as EVH and Joey Vera, my mother was friends with Tony Cavazzo (so she knew Carlos also). My 80s DNA is quite a bit stronger than you assume.
1 - 11 of 11 Posts
