How to solve a hump around fret 12 ?
14K views 17 replies 7 participants last post by  Silverburst
The most inexpensive option is just to level the frets.
I'm never one to suggest the biggest job is the right job, if it's at the wrong time, and I wouldn't suggest throwing away 80% fret life just to get rid of a hump. When it's time to refret, that's the time to plane the board true. Now is the time to level the frets. You want to do it under tension, and you want to do it in enough relief that you're cutting a little off the first and last frets as well as the hump, so it will minimize the amount of fret you need to remove overall.
