1 - 12 of 12 Posts
· Registered
...from waist high, it was hung around my neck, the strap unhooked from the left hook and the axe slammed into the wooden floor back first and then turned on the string side from the impact !!!
:evil: :evil: :evil: :( :( :(
the guitar has of course detuned a significant amount.
visually everything seems fine (apart from a tiny scratch around the floating bridge) but how can I check whether something is broken inside the neck or somewhere else???
· Registered
there's nothing to break inside the neck, a fall won't hurt anything inside usually. Basically if it looks ok, and still plays and works fine it is fine. Acoustics are another story, braces can pop, end blocks etc, but electrics are pretty resiliant. If there isn't any visible damage I'd say you're perfectly fine.
· Registered
sniperfrommars1 said:
oh the joy of well seated dimarzio cliplock straps :> Never leave home without em :> I usually use the original screws with my cliplock straps they can usually be forced through the brass bushing with a little work.
I use the dimarzio screws but i take some string and jam it into the old screw hole then screw em in. its an old old woodworking trick for stripped screw holes, works like a charm.
· Registered
I just repaired mine with some glue and a matchstick *LOL* It was a cliplock strap but that didn't help since it was the screw that ripped out, not the strap itself.
· Registered
Discussion Starter · #10 ·
Ankhnaten said:
If it went flat, I would look at the trem posts, and make sure the wood didn't split where they are seated. I had a Universe do that, and with the extra tension, I am paranoid about it with my 1077's...lol
will do
to all of you talking about straplocks (or whatever it's called), how much is a straplock system?
· Registered
403 said:
will do
And what brand would you recommend?
· Registered
I use a variety of strap locks...i've broken them all, including the Dimarzio things. Those work well, I will admit, but i like my recessed Dunlops. Except on V's where the back of the neck one might release when it pushed against ya'.
That's just me...
1 - 12 of 12 Posts
