1 - 4 of 4 Posts
Hi,
I need a little help about a bugera 333xl
I have 212 harley Benton cab and it has 16 ohms and 8 ohms... will it work or I need to buy a new one for it?
You mean the 2 x 12 cabinet has one 8 ohm speaker and one 16 ohm speaker? If that is the case, I would replace one speaker so both had the same impedance. Then you can set your impedance switch to the proper setting and not worry about it causing a problem with the amp.
1 - 4 of 4 Posts
