1 - 19 of 19 Posts
· Registered
Hi all, I recently got a '95 Iceman IC-350 - the one non-signature model that featured a Floyd Rose. It's fitted with the original Lo-TRS II trem. This model was pretty bad to begin with and after @ 25 years of use it's fairly worn and tuning stability is not the greatest. I know this has been discussed all over the place before, but everything I come across is fairly dated.
I'm looking for a direct replacement that requires no modification to the trem cavity and have a high preference to keep it Ibanez branded. Knowing that not all floyd style trems fit in all cavities, Ibanez made some greats & some duds, and since the last time i really looked Ibanez developed some newer models... What is my best option to replace the Lo-TRS II given my preferences?
Thank you in advance for any help.
· Registered
Would be hard to stay with Ibanez branded stuff as most of it (Edge, Lo Pro, post-2003 models etc.) is not a direct fit. There is also the Lo TRS I which is slightly better than the II, and was put on MIJ guitars in the past.
Otherwise, most OFR types will fit the TRS route and post spacing. So an actual OFR is possible, Schaller, and the Gotoh GE1996T. The latter may be a better fit as the stock radius of the saddles is 14", which is closer to Ibanez spec on locking trem equipped guitars, while OFR is 10". The Gotoh also comes with locking studs (like Edge and Lo Pro), a brass block, and the straight knife edge on the bass side makes up for any tolerance issue in stud spacing.
· Registered
Without any kind of modification it will be a hard find to keep Ibanez branded.
Especially if it had a Floyd originally.
TRS ii = import trash.
It's not really worth the weight in metals it was made of.
That said, you maybe able to sell it as parts if the saddles are in decent shape.
The TRS I as mentioned above was the exact same design, so it will be a drop in replacement.
They were good enough to be sold on their prestige line in Japan before bringing back the edge lopro in around 2005.
Do keep in mind that they don't still use them for a reason though. They are not that great, but better then what you have and they don't need any kind of work to fit in your current set up.
Lastly, and much more recently (prob the easier option to find) the Ibanez DL that comes on Jem Jrs.
Ibanez branded, just like your after. Alot of people will gripe about them but the one on my Jr is fantastic. Even better then the floyd I upgraded to on my rg450.
It could be that I just got a lucky one or that I have not worn it out as much as other claim for it, but I would say the DL is about on par with the TRS 1 from my experience with my 99 rg550 before I sold it.
Gets the job done.
I would however say that of all the Ibanez options available to you with out modification... It would be best to not go Ibanez on this.
9/10 an branded tremolo is no where near the quality of say a Floyd or Gotoh who don't make guitars and just make hardware.
A better option for you may even just be an Official Floyd, as all licenced bridges should be a drop in replacement for the Floyd routes.
Or even just a Gotoh which are known to have slightly smaller profiles than a standard Ibanez type and seems to be the go to for many who swap the stock lower end Ibanez trems and don't want to mod to fit the high end edge trems.
Here's a pic with the Floyd installed on the 450. No mods needed, not even a change in the original trem posts or studs.
Musical instrument String instrument Guitar accessory String instrument accessory Musical instrument accessory
· Registered
Like others have mentioned, the gotoh Floyd... The ge1996t is a drop in fit, but only if you use 10 gauge strings. If you use 9's then the cavity doesn't allow enough space to intonate properly. I have a js100 I put a custom neck on and a gotoh Floyd. I use 9's so I used a rotary tool to extend the cavity a bit. Plus the gotoh is around $110-$135 US on eBay. It doesn't come with a new locking nut. It has a 16 inch radius, so depending on your neck, you may need shim for the saddles to match your neck radius.
The close up pic of the bridge was when the guitar had 10's. You can see the clearance the Allen screws have. It just fits but works.
· Registered
I know that works with a Schaller Floyd, and probably with the original as well. But I looked into it with the gotoh and they won't fit using Schallers allens. The spacing of the base plate where the screws go through are too narrow. Unless there's another brand you're aware of?
· Registered
I'm not exactly sure what you mean... but after you posted your last post I did a search, the allens that I saw before were like these.
https://www.ebay.com/itm/233253606592
But then I saw these! I had no idea these existed.
https://reverb.com/item/404931-schaller-short-locking-screws-m4x33-5-for-floyd-rose-tremolo
These would work because they are not thick. If I had known I would have just bought the ones on reverb. I thought Schaller only made the thicker ones back when I did the bridge install.
· Registered
That's a string lock screw.
The Allen key is the tool you use to tighten hex bolts/screws
They come in a bunch of different sizes, and the thickness of them depends on the style of the bridge when they come out.
Some of the thicker ones like in your first post allow you to string the ball end of the strings through the tube end. That's why they tend to be big boys.
· Registered
Yeahhhh and they're both Allen keyed. And they are both the string lock screw, the shorter thick ones do the same as the longer ones. I have a Schaller Floyd on a custom strat style warmoth guitar that has them. They are simply shorter. No Floyd rose style bridge can be used with the ball ends attached to the string. I think we (or I) may have misunderstood some terminology earlier. I reread and I referred to what you call the string lock screw as an Allen screw... Because well, it is an Allen screw. But "string lock screw" is a more specific term. But the short thick ones I shared earlier are also string lock screws.
· Registered
I understood what you were getting at. But every screw on a Floyd is an Allen style lol. So I wanted to be sure.
There are some that you can use the ball ends in, they just are not always that good.
Ibanez edge 2 and 3 for example allow ball ends in the trem, I used to load them like that all the time.
I had an old Peavy tracer from the 80s that had the weird back loaded string locks as well. You would load the string through the Allen key opening and string it up through the saddle.
Once it was somewhat tight you then locked it in like normal.
I don't remember the brand of bridge on it, but I don't think it was an OFR
· Registered
I installed an Original Floyd Rose to replace my LO-TRS II TREM. The OFR posts screw into the body just fine. The spacing is perfect. The route around the trem isn't an exact match but I think that's OK. My block is a little long for my S Series even though it is the same length. I figure the height of the strings from the base must be a little different. So I have to keep the back cover off the guitar or buy a shorter block.
· Registered
Hi everyone. This thread is a bit old, but I would like to share my thoughts on this topic. I own an Ibanez RGR320 (https://ibanez.fandom.com/wiki/RGR320).
It was equipped with the Lo-trs ii trem and of course after 15 years of use, I started having tuning issues. So, I replaced it with a Gotoh 1996t. The tremolo was almost a perfect fit, there was minimal routing needed to the body due to the string tightening screws (I don't if it's the right way to call them) being a bit long. To me this trem is perfect regarding tuning stability and I think I noticed a bit of a sonic difference (to the better). But.... here are two issues to be considered imho:
1. The block of the trem is a tad big and I cannot close the backplate of the guitar body. That was not a big deal for me, because I don't care much about this kind of stuff. I just wanted to regain tuning stability and enjoy playing the guitar.
2. Even though string spacing etc. is fine, there IS an issue that has to do with the string space between the 6th and the 1st string. It is just a liiiiitle bit wider that the original Lo-trs ii trem. This means that both the 6th and and the 1st string are just a liiiitle bit closer to the edge of the fretboard. Unfortunately this means that I have to be extra careful especially when soloing on the 1st string because I can easily drag the string off the fretboard (and I believe we all know how this translates sonically :D )
The 2nd issue I mentioned was kind of a serious issue for me, but I got used to it after a while. However now I am just thinking about selling the Gotoh and just get a Lo pro Edge (after consulting with Ibanez probably). I don't care much about routing the guitar....it's not that much of a collector's item, nor will I sell it anytime (it is my first guitar ever so I have a special connection to it :giggle:).
Anyway, hope that this is useful.
· Registered
The gotoh comes equipt with the sustain block that you order it with. I believe they come in... 34mm, 37mm and... 40mm? An RG needs the 34mm version. As for the lo pro, they're awesome. I have one in one of my guitars and it's my favorite for sure. They're a bit expensive... I just bought one from thouman music over in your country for a really reasonable price. Though if you are going to do that I would recommend getting the new posts installed with it to give you that extra tuning stability. Unless you already had the gotoh's post inserts drilled and installed already... The inserts that come with the gotoh are actually identical to the lo pro and original edge. The posts for the edge and lo pro edge screw right into the gotoh inserts.
· Registered
Truth be told, I bought the Gotoh used, so I did not have much of a choice for the sustain block.
Well to me, you can't go wrong with the higher end ibanez trems. I've had the Edge pro on one of my 6 strings and it was super awesome. Still trying to figure out why I sold that guitar with the Edge pro. I also have the Edge 7 in my RGD2127 and it slays.
Anyway, now I need to be 100% sure about the 1st-6th string spacing, to be sure I can install one of these higher end ibanez trems to my humble RGR.
1 - 19 of 19 Posts
