1 - 20 of 24 Posts
Hi everyone,
First off, I'd like to say that this seems like a great board filled with wonderfully informative members.
I have a few questions if you don't mind. I should say that I'm not very knowledgable with any technical aspects of guitars (so Please be patient).
I'm currently trying to dust off and fix up an Ibanez 1993 Model RG570 that is in rough shape.
1.) What is the reputation of this model of guitar? Good/Bad.
2.) What are the best methods of cleaning this thing up? Any recommeded cleaners, oils and rags for the body, frets and neck? What should I use to clean up the roughed up looking pickups and tremolo system that contain some rust?
3.) What is the best online site to find minor replacement parts? Currently, I'm looking to replace the pickup rings, pickup ring screws and pickup springs and height screws. More importantly I'm also looking to get some blocks and block bolts for the nutlock system. Is the stewmac site a good starting point or are there better and cheaper sites to go to? Does it matter if I buy authentic parts or generic parts?
4.) (I probably won't be messing with the task in this question for awhile but out of curiousity) What would you do with a body that has been stripped of its paint and coating? Would you refinish or repaint it or what other options are available, if any?
I certainly would appreciate any information from you all. Thank you! :)
Hi 570, welcome to Jemsite.
In response to your questions...
1) I haven't played a 570 but they do seem to have a god reputation, as does most of the RG series.
2) Check here, excellent advice: http://www.ibanezrules.com/tech/grunge/grunge_1.htm
3) I'm not too clued up on that one, you might want to try searching the internet. Try Rich Harris' website (www.ibanezrules.com).
4) Sorry, I can't help you on that one. But someone round here will be able to!
Hope this helps,
'87
Welcome to the forums.
Not sure how much help I can be. I do own an older RG570 though..
1. What is the reputation of this model of guitar? Good/Bad.
For those that like Ibanez, pretty much any Japanese Edge, or Lo-pro equipped RG has a good rep.
2. What are the best methods of cleaning this thing up? Any recommeded cleaners, oils and rags for the body, frets and neck? What should I use to clean up the roughed up looking pickups and tremolo system that contain some rust?
See above link from Shredder87.
3. What is the best online site to find minor replacement parts? Currently, I'm looking to replace the pickup rings, pickup ring screws and pickup springs and height screws. More importantly I'm also looking to get some blocks and block bolts for the nutlock system. Is the stewmac site a good starting point or are there better and cheaper sites to go to? Does it matter if I buy authentic parts or generic parts?
It might actually be cheaper/easier to actually refinish the pickup rings, screws, and bolts yourself. Clean and spray with some glossy black.
Are you missing the "blocks and block bolts" for the locking nut? If so, you may need to buy some Ibanez replacement parts. Not sure if stewmac have these unfortunately. I'd order through a store.
I don't think generic parts will fit the trem, or the locking nut.
4. (I probably won't be messing with the task in this question for awhile but out of curiousity) What would you do with a body that has been stripped of its paint and coating? Would you refinish or repaint it or what other options are available, if any?
If the wood was good and free of filler, I'd most probably take a blow torch to bits of it, then stain it.
I think the older RG570s are great, as I have a handful of them and they are really easy to customize, etc. I think of them as the Honda Civic of electric guitars. Not expensive, but play great and you can really trick them out. They also give you a pretty good tonal palate to work with.
You could get the Planet Waves body restore kit. I just used the Step 3 "Shine", and it worked wonders on one of my older guitars.
As far at the fretboard and neck, a little steel wool on the frets and some bore oil will go a long way. I use a pretty basic fretboard conditioner, and it works fine. It cleans up nice, and doesn't leave any buildup or a trace it was ever even there (except for a nice shine).
I've probably got some parts lying around here that I won't use (pickup rings, knobs, etc.) so if you wanna PM me or shoot me an e-mail, I'll see what I can do to help you get started.
I use electronics parts cleaner for my trems, believe it or not. I take the whole thing apart and spray a little on each piece, scrub them, and then put it back together and for some reason it works great for me.
As far as the body, if you wanna go cheap and get a good job done, go see a local autobody painter, and offer him like $100 to shoot your gutair and clear it. That would be for starters. Otherwise, if you wanna make a little bit of an investment and get something fancy done, there are plenty of people on this board to contact that will do a more custom job, i.e. graphics, swirl, and you could really have some fun.
Discussion Starter · #5 ·
Hope this helps,
'87
Thank you, Shredder87. I've just now bookmarked that site and read a bit of it. A good guide and cool site. That guy is very meticulous with his guitar like any self respecting guitar owner should be.
I cannot wait to get this thing cleaned up. I feel a bit bad that I let it deteriorate (especially the rusty pickups). I bought it used and I guess I really don't remember how good or bad it looked to begin with since it has been so long ago. Maybe it was a bit rough to start out with.
Thanks again.
Discussion Starter · #7 ·
Hi Wilch. Thanks for the welcome and the response.
First off, I can't repeat the words here that I exclaimed after seeing the pic of your guitar. Friggen Sweet (would be a massive understatement). Nice work. And nice work making mine look like crap! :)
Yep, I'm missing the 3 blocks and block bolts. I'm also missing some humbucker springs and a few ring screws which is why I need to replace them instead of giving them a makeover.
I was a little impatient so I went ahead and grabbed a few things from stewmac. If they don't work or fit properly, I guess I can always return them. Not that this thing is remotely valuable or anything but will placing generic parts on this be some sort of taboo move in the guitar world? I think, at the very least, I'd like to track down an original trem arm from another '93 model if possible (maybe knobs too).
Discussion Starter · #8 ·
Hi jaxadam. Thanks for the help.
I like the Civic analogy. I'm glad you mentioned that electronic parts cleaner on your trem parts. I read once that someone used WD40 on it. Would this type of thing work or do you have something in particular that works best? I was reluctant with the thought about taking everything off but it is reassuring that this is your common practice. Can I use steel wool on the pickups and tremolo or is that too abrasive? Thanks for any additional advice.
Thanks for the offer on the rings and knobs - I don't want to be a bother but that is very generous. Just out of curiousity do you use plastic or metal/chrome type rings?
Thanks again!
Wilch, that 570 is HOT!
To the original poster -- the RG570 is a GREAT guitar. Nice to know you're restoring it and giving it a little love that it deserves. The RG570 is pretty much an RG550 without a pickguard, and basically the RG550 is legendary. You can improve the 570 with better pickups if you wanted to, but the basic guitar is a great example of a made in Japan Ibanez with a superb neck and the greatest bridge ever.
Welcome to the site. Hope you stick around.
All the tremolo arms for Edge, Lo-Pro and Edge Pro bridges are the same. You can easily find one at the parts at IbanezRules.com or e-Bay. You need the one with the 2 nylon bushings. Try to replace the parts that are missing with original Ibanez stuff, though. :) It's not hard to come by. I wouldn't use steel wool on anything except the fretboard and frets themselves. Metal pickup rings are best. Plastic ones suck a bit. Is it cosmo hardware (like black chrome)? You should be able to find a couple of those quite easily. Rich at IbanezRules has parts. e-Bay does too. For the fretboard, I swear by Fret Doctor, it's amazing stuff. http://www.beafifer.com/boredoctor.htm
EDIT:
Lock nut: 170084159927 <--- paste the number into e-Bay's search box.
Pickup rings: 120089186342
Knobs: 170084156056
Trem arm: $18 at IbanezRules.com
Always check Rich's stock first, he usually has good prices on everything.
thanks dude. :) I've had it since new. It was the first Ibanez I bought, and the first thing to ever deplete my bank account to near 0. I saved up for so long. lol
I'm surprised at how well the guitar has stood up to the abuse. Granted I always wiped it down, no matter how drunk I was (lol). It was my primary axe back when I played at pubs, parties, and cruises.
You know, the generic stuff might fit. I'm really not too sure now.
Nah, stuff the whole "taboo" thing. Seeing as you're almost starting from scratch, I say make it the guitar you want. That's what I reckon.
Ibanezdirhard said:
nice guitar dude, i used to own one exactly like it and my friend had the blue version.
i sold it in 1999 or early 2000 i don't remeber exactly.
Thanks dude :).
I don't think I could ever part with mine. I remember my mate always wanted the blue version!
i was kicking myself 6 months later. for selling it,
it was during one of my no more floyd rose stages.
Ah, I'm having one of those now. (Have been for the past few years though, lol). The guitar that I always pick up now is my RG421 with EVO's. It's just easier to pick up and jam with.
Discussion Starter · #16 ·
I've finally received some minor generic parts so I'm ready to get started on replacing and adding them. I had already ordered a set of plastic pickup rings because they were only $4 and I don't have a whole lot to spend. I got some replacement ring screws and pickup springs because the Ibanez were missing quite a bit of those (it's amazing how you can spend $25 and receive a little bag with only some simple hardware). Also I received the string clamps and the screws for them to replace those that were missing on the locking nut.
Dee, thanks for those numbers to search on e bay. Eventually I would definitely like to get some metal pickup rings. Also, thanks to Wilch I now realize what bobbin toppers are and that they can be replaced as well which I would like to do. I think my next replacement parts will be the knobs and tremolo bar.
Two quick questions if you don't mind.
I'm missing the hex bar (or allen wrench) that is suppose to come with the guitar and I believe sits next to the pegs. I have a partial wrench hex set and a few bit sets of hex bars but I noticed that every one I had did NOT fit. I believe 1/8" is just a bit too big. Any idea on what size the hex bar should be so I can pick one up? Thanks.
Also, once I get that hex bar to release the strings I will finally get started on attempting to clean the bridge up. I still have not found a specific cleaner so I'm going to try WD-40 on it. If you all see that this would not be the best solution, please give me a yell. Thank you.
One last thing (sorry, I know I've rambled on long enough). Is there anything other than the springs that is suppose to hold the whole bridge unit in place? I took the spring bar off and took the springs off and the whole thing just sorta flopped out.
Thanks for any advice once again. I'll get her up and running in no time!
Hex bar = allen key/wrench?
You need these sizes:
7mm box-wrench for the truss rod
4mm allen key for bridge height adjustments posts
3mm allen key for the lock nut and string lock blocks
1.5mm allen key for the locking stud (inside the bridge height adjustment posts)
...Also, thanks to Wilch I now realize what bobbin toppers are and that they can be replaced as well which I would like to do.
not a prob dude.
...One last thing (sorry, I know I've rambled on long enough). Is there anything other than the springs that is suppose to hold the whole bridge unit in place? I took the spring bar off and took the springs off and the whole thing just sorta flopped out.
Nope, the only thing that holds the bridge in are the springs which pull the bridge up against the posts to stop it from falling out.
Be careful with the knife edges on the trem. They should be free of any imperfections, otherwise the guitar won't return in tune after using the whammy.
Discussion Starter · #19 ·
Dee, thank you for those specs. That is perfect. I'll be heading to my home improvement store to buy some singles.
Wilch, thanks for that information. I was a bit worried I needed more parts to keep that sucker intact. I noticed that the knife edges are a bit different. On one side it is a flat edge and on the other side it is arched. I don't know if that was built like that or if someone filed it down.
I have one more question and yes this is going to sound dumb. Is my fingerboard made of maple?
I've been doing what the guy suggested on the Ibanezrules site (great site by the way) with the steel wool to clean it. I broke out the Dunlop fingerboard cleaning kit and both the #1 and #2 (cleaner and conditioner) state that it is "not" to be used on maple fingerboards.
Here is a link to the fingerboard if that helps. If a better pic is needed then please let me know.
http://img69.imageshack.us/img69/4876/dsc01756zk3.jpg
Yep, one knife edge is supposed to be flat, and the other arched.
Your fingerboard is Rosewood. Maple boards are the white'ish ones.
Maple:
1 - 20 of 24 Posts
