1 - 4 of 4 Posts
I've got a Jem Jr Sp with the Ibanez Standard DL Trem. Recently I installed a brass tone block, and to do so, I had to disassemble the Trem. After putting it all back together, I'm getting some buzz from the bridge.
My question is:
On a Standard DL trem system, are the saddles string specific, or can any of them be used in any of the 6 spots?
Thanks in advance
the way to tell will be if the baseplate is stepped to make the radius. If it is, then the saddles are likely to be all the same. If the baseplate is flat, then the saddles will be different sizes, to match the radius.
Discussion Starter · #4 ·
I finally got a response from ibanez. They said that the tremolo on the Jem Jr DOES have saddles for specific strings. On the bottom of the saddles there are marks that show which string they're for.
1 - 4 of 4 Posts
