1 - 12 of 12 Posts
Discussion Starter #1
hello friends I was wondering if some of you could give some advice to improve the performance of the edge III bridge... I would swap it for a OFR but it's dificult to find bridges here in Mexico.. so until I can get one... what can I do to improve tunning stability?
Damn!! I would had bougth a 1550...
Sorry for mi english..
I think no other option but to change the trem, anyway I used edge 3 trem all the the time at the store and they work great! I think you need to really set it up perfectly for it to function perfectly
the edge 3 wont swap out directly with an original floyd or at least i dont think it will . i am sure someone will know for sure .
Discussion Starter #4
Ok.. so anyone could give some advice to set it up? Because a think there's no much things to set apart from the spring's claw..
Just like any other trem you need to stretch the string first before locking it
Discussion Starter #6
I was wondering too.. old strings could affect stability?
I do it anytime I change the strings buddy ;) what more can I do?
How about fitting a Tremol-no? Should improve stability and give a more accurate return to pitch, I think.
The tremolno is a blocking mechanism, either blocking tremolo function altogether or only allowing pitched to be lowered. It does give a more accurate return to pitch, but you cant use the bar to raise pitch in this state.
Discussion Starter #10
[quoute="sniperfrommars1"] but you cant use the bar to raise pitch in this state.
[/quoute]
and it's difficult to find one of those in mexico... :s
Definitely check ibanezrules.com but also
1. Stretch strings in properly
2. Adjust springs so that the angle of the trem is parallel to the body
3. Lock the nut, but not too tight
Put a bit of chapstick on the knife edges. I would imagine they sell that in mexico. Rich shows you how to do that at www.ibanezrules.com Pretty much you need to completely go over that website with a fine toothed comb, on top of t hat he has some of the best guitar porn ive ever seen.
1 - 12 of 12 Posts
