although he is speaking of a different speaker combination, the impedance remains the same. i generally like to follow, or take into deep consideration, advice of people like him, your usual tech-head type. i am running a legacy combo, which uses the 8Ω cab, and have yet to experience any load problems. however, i have been wrong before. and impedance, ohm settings, and speaker loads are topics that usually greatly confuse me. (i sure am a lot of help, huh?)Brian D said:4Ω. The impedance switch needs to be set to a value lower that the lowest impedance load. 16Ω and 8Ω would equal 5.33Ω. So 4Ω is the correct setting.
8 ohm cabinet, 8 ohm setting on the amp. 2 - 8 ohm cabinets, 4 ohm setting on the amp. Not sure where you get your info, but I would find another source.knarfzednem said:i believe it's an 8Ω cabinet, so set the amp to 4Ω.
