1 - 6 of 6 Posts
I have a tremolo problem. While i was playing my D string suddenly dropped low and then i checked the trmolo. The inotation block just popped up and making the string less tight. And the fine tuner on the D string is supposed to push a bar down which i think holds the intonation block down. Now the bar has popped up, and i cant push it back down for the screw to hold it down
Any Ideas?
Discussion Starter · #4 ·
Ok this time i used a little bit more force and got the fine tuner screw unstuck without damaging it. Now the bar is a little too short for the screw to push down.
ah, by replacing I meant, slide it back towards the rear of the guitar,. it has slipped forward,.. thereby taking the rod out of reach of the fine tuner. Not all the way offcourse, be sure to check intonation.
Let's fix this baby :D
Discussion Starter · #6 ·
thanks ive got it all fixed. Ive changed the intonation on all strings as close as i can. I dont bother besides i dont even have a intonation tool. No big performances soon so i should be fine.
Thanks Again :)
1 - 6 of 6 Posts
