21 - 40 of 544 Posts
I've tried a Suhr. It was very nice. Was it ultimately better than many of the J Customs that I have tried/used? I found it to have a different feel that I wasn't particularly comfortable with. So, was it better, No. I've owned a Tom Anderson. Was it far and away better, No.
It all comes down to what you like. I now have 4 J Customs and each time I pick them up and play them, well......it's just feels right to me.
One thing that I hear is that the customer service offered by Suhr is fantastic. Ibby needs much work in that area, apparently.
I have no tuning issues with any of my Edge Zero bars and all 4 of my J Customs have this. They work great night in, night out and in and out of the studio.
Stainless steel frets are not the be all to end all. Sure they last longer, but what I found was a strange sound almost....thin? Again, all the pieces of the guitar probably have something to do with it as well.
Of all the guitars I have ever owned and/or played, nothing comes close to my J-Customs with regards to tone, playability, finish and vibe. Their necks and fretwork are in a league of their own imo. I have not played a superstrat/RG that resonates more… they sing! I also love the new edge zero trems, as much, if not more than my previous favourite, the low pro edge. My next guitar will most probably be another J-Custom…
Suhr moderns are cheaper than the list prices on Suhr's site. Contact mattsmusic and ask them to price one for you. I spec'd one with a handful of options and it came to $2700. I believe list price for the guitar I built was around 4k.
Both are great and it all comes down to personal taste. I'd go J Custom as Suhr's look a little bland to me. If I'm paying a 4 figure sum for a guitar I want it to look like a 4 figure guitar. That Suhr Purple Nova is sweet though.
i asked this qn few yrs back, and thus sold my J-custom and now im only left with a Suhr modern.
my modern is a basswood, maple top, maple neck and pau ferro board comapre to standard J-custom with maho body, maple top, maple neck and rosewood board.
Both guitars have very good quality finish. But i do not know does both uses the same dying methods, what i can tell is the poly finish on the modern looks alot thinner than that on the J-custom. The maple top use by Suhr definetly own any standard J-custom top nowadays.
Having said that, the J-custom has the bling factor of vine inlays which will set you back alot if you were to custom it on a Suhr.
Both guitars have excellent fret work, although the ones on J-custom looks nicer with rounded edges and neck binding, just some cosmetic stuffs. The fret ends on the modern feels good as well, and of cause you have the options to choose whether you want them to be SS.
Neck fitting: Base on these 2 guitars, i will say the modern has a better neck fit into the pocket, there is a slightly bigger gap on both side of the J-custom, and for those who are particular about neck fit, and tone transfer/vibration etc etc between the neck to the body, J-custom has a rounded end neck heel, thus will not have full contact with the neck pocket and the modern has a square heel which will has full contact with the neck pocket.
Neck Profile: I always thought Ibanez wizard profile are the perfect shape for my hands, but after playing the thinner modern profile, it definetly fits my hand better. I can only describe it as being not so wide compare to Ibanez wizard, but is a little bit thicker, which allows me to grab the neck better. I bought a modern without trying as there is no dealer in my country, was worried about the neck profile initially, but now i know the modern neck fits my hand better, you should try it out to see if you like it.
2 main factors which makes me decide to sell the J-custom are the neck profile and the sound coming from the Suhr. I know both uses diff wood, but the Suhr resonate more and i find the clean sounding of the Suhr is alot sweeter and clearer compared to the J-custom, im not sure if its the work of the pickups or bodywood though.
And from doing some readings online, i read that maho body will sounds nicer with a maho neck compared to a maho body with maple neck. Maybe something you would like to look into.
Hope these infos help =)
Suhr by a million miles. Mine is by far the greatest guitar I have ever played, and I have played a LOT. The instant I bought it, it pretty much made my other 15 guitars irrelevant and my search for a number one ended.
Suhr make unbelieveable guitars that sound even better than they look.
Not the same animal at all but I'd give the "build quality" edge to Suhr because of the fretwork. Suhr Pleks everything. Ibanez fretwork can be "ok" at best, but its hit and miss. Usually but not always they can be set 'medium to medium low', but never 'super low' like I prefer, without some aftermarket work.
They aren't the most level on any example I've seen, and I've seen a lot over the years, and they dont glue them in or crimp the tangs so they tend to be loose and move around some over the years, making them less level than when they left the factory. They should really invest in at least glueing the frets or adjusting the tang/fret slot on the high end stuff, and get a Plek machine. For what they charge, they can afford it.
Yep, I'm sure. Try this if you have a mechanical ruler: Set the guitar up so that at the 14th fret, the distance between the bottom of the string and the fret is .03" high E, .05" low E, sloping up slowly between the two. Then see how good it is! Do whole step bends all the way up the high E and see if they choke. Those measurements are about the limit the physics of string vibration will allow, IF the fretwork is spot on. If its not, you wont even get close to that without excessive buzz, choking out.
I would choose the Ibanez over the Suhr because i am addicted to the wizard neck profile. I love the way they feel and play. I am not crazy about Suhr because the neck feels like someone cut a baseball bat in half and put frets on it. This is just my opinion but i am not paying 2 or 3 grand for a Fender.
J. Custom hands down!!!!!
Ive just borrow my friend suhr modern custom... It material quality and workmanship of the guitar are better and really worth the money spend on it... J custom or jem lose... But jem looks nicer to me and suhr guitar bridge are better,stays in tune better than ibanez edge.....
Rg8670 and rg8570dz... Rg8670 is the ebony board with edge pro... But edge zero is actually better than the previous edge model... The suhr modern custom spec is pao ferro frets with mahagony body and neck, gold hardware sperzel tuners hsh config,stainless steel medium jumbo frets....flame maple top
He let me try the guitar for few days because if wanted to trade his suhr modern custom with my jem7vwh 2008 or jem77fp2 plus top up cash... Im still considering... Suhr plays better sounds better and feels better than my jems... But i like jem looks and design... Maybe i keep the jem if he wants higher cash top up...
