I haven't done it on a JEM, but it shouldn't be a very big deal to drop a three-way blade switch in there. (A LP-style 3-way switch would be more work.) You can wire it any way you want. It would actually make it a lot more like the JS wiring.
Or you could simply leave the 5-way switch there and change the wiring to give you the bridge/neck combinations you want, and skip the middle pup connections. That's just a wiring change. Pretty simple to do, once you figure out exactly what you want it to do.
