Hello!
I have had big problem - as you can read from here:
http://www.jemsite.com/forums/f31/wtb-777dy-neck-122781.html
After asking for repairing it from few places here in Finland the luthiers were too afraid to fix it so I had to do it myself:
There is a starting point:
http://imageshack.us/a/img831/8230/01nicebutbroken.jpg
http://imageshack.us/a/img703/9315/02behind.jpg
From these pics you can see better how bad the crack is (with truss rod bolt on):
http://imageshack.us/a/img835/5278/03scratch.jpg
Before you can really (but gently) twist the neck crack open you have to remove truss rod bolt:
http://imageshack.us/a/img253/3562/05thussrodremoval.jpg
http://imageshack.us/a/img818/2904/03scratch02.jpg
Now you can see the big picture:
http://imageshack.us/a/img842/5303/06nowyoucantwist.jpg
Here I show the method how to put the epoxy to go in - after glueing just sweep inside the crack
with some plastic part to fill the cracked hole properly with glue:
http://imageshack.us/a/img840/4831/08methodtohavethegluego.jpg
http://imageshack.us/a/img594/3984/09myglue.jpg
In this photo I press (gently, gently) with the nearest presser the crack more open for glueing with epoxy and
just in case I covered neck with painters tape:
http://imageshack.us/a/img40/4316/10gentlypressingthehole.jpg
Here the crack is showing its whole beauty when I'm pressing it more open:
http://imageshack.us/a/img846/9030/11holeandotherneckiscov.jpg
Now its glued properly - it's important that you have the nut holes filled with paper or
something during glueing - and when you press the neck back together remember to take paper stuff out and keep holes clean from glue that presses out:
http://imageshack.us/a/img21/8117/12gluedremembertofillnu.jpg
Ok here I press the headstock back together. First one of the pressers keeps the wood-stick tight against the table so headstock can lean against it during the pressing. The last press keeps the neck in place and the middle one presses headstock back to its original postition. No we have a nice 24h dry-time.
After 24h hours and after a little sanding with 240 paper headstock looks like this:
I can't feel the glued joint with my wedding-finger:
http://imageshack.us/a/img89/3149/14after24hoursandlittle.jpg
After putting my JEM 777DY/77FP back together it looks pretty good and here
the neck is back in its full tension with strings attached:
And oh - JEMs small brotha 77VBK wanted also in picture:
Hopefully this will help you in cases like mine.
Silver_Surfer
Silver_Surfer
