thank you Wolfgang!It's a fine guitar. I have a '94 and it is my "daily driver" since over 20 years now. Great player. Maintenance was only changing strings and sometimes cleaning and a little bit oiling the fretboard. Wish i had a car that is so cheap in maintenance for over 20 years.
Cheers !
Wolfgang
Yep, she will still exist during i am ten feet under ground. (-;thank you Wolfgang!
I have a 2001, and while she is not "quite" that daily driver (i have a 8520SDE for that), it is super comforting to know that these ebony FB/LPE 7VH's are soooo durable:smile_big:
The volute is there because the necks are no longer scarf joint but are laminate and have 3 [or 5 if you wish] pieces of wood that run the length of the neck instead of splitting at the nut with a separate headstock piece.I've got a 1994 7VWH, it was my main live guitar from 2005 until an accident last month where the neck split. I don't know about the most refined Jem but the only significant move forward with the newer models is the volute at the back of the neck behind the nut, same volute that was designed prevent the neck split that happened on my guitar. I haven't played any recent 7V's with Rosewood fretboard (not since before I bought own 7V), my 1994 guitar is a beautiful instrument though, but I definitely think there is room for improvement.
Honestly the Edge/Lo-Pro trem can be improved, the pop in trem arm is nice but
1. The trem-arm bushings wear out very quickly if you remove the arm a lot, and you kinda need to if you want to put the guitar back in the case. After a while you will develop a lot of play in the trem if you don't address it, it would be nice if removing/replacing the trem arm didn't wear down the bushes so much but it's integral to the design. The bushes aren't cheap either, the prices on them are robbery.
2. The Trem arm holder has a tendency to work itself loose and when it does it can be very difficult to get it to stay again, causing the trem to have play in the socket holder. I dealt with that issue for years on my 7V before I finally fixed it properly, thankfully it hasn't shown up on the 777 yet. When I eventually broke the 7V's trem arm socket holder last year (years of hard use) it took a few of attempts before I finally got the new socket to stop working loose.
They could improve the pop in design in a way that could be retrofitted quite easily, I still prefer it to the Floyd Rose screw design but I think systems such as the Gotoh 1996 could be used as inspiration. Aside from that the Jem could come with a Sustainiac neck pickup, we've been saying it for years and though Steve uses them extensively he refuses have them put on the guitars. On top of that the Jems could really benefit from having stainless steel frets, I'm already beginning to notice visible fret wear on my 2 year old 30th Anniversary Jem 777, if you play the guitars a lot then SS frets are a godsend.
Volute : And as a side effect the neck is much stronger with this design, and cracks are much less common than the old scarf joint necks. Also you could argue the necks are 7 piece, since the headstock itself has 2 additional pieces of wood, that annoys me with the newer guitars because it's quite ugly to look at.The volute is there because the necks are no longer scarf joint but are laminate and have 3 [or 5 if you wish] pieces of wood that run the length of the neck instead of splitting at the nut with a separate headstock piece.
If you haven't learned to flame the bushing to distort them and tighten them up again, and again, and again until you finally need to replace them then you haven't been paying very close attention to the forum. It's been publicly shared for years now.
And when the holder tube becomes loose it only has to be tightened right once, instructions have been in my tech section for 15 years. Most people try and use a screwdriver and use the slots in the top to tighten it which is just never going to work and you'll probably just end up putting a big scratch on the trem when you slip.
Otherwise, if I had to guess, Steve is finally putting the sustainer in the production model, like Joe did years ago. In fact I bet Joe $1 that within 2 years Steve would release one in the JEM. Looks like I owe Joe a $1 as it's taken alot longer, if that is what is coming.
Is this the big news he was talking about that will be shown at this coming NAMM show?Otherwise, if I had to guess, Steve is finally putting the sustainer in the production model
A guess is just that.Is this the big news he was talking about that will be shown at this coming NAMM show?
Cool....I have always wondered why the sustainiac was never offered on his Sig. JEM 7VA guess is just that.
Because it would have required a deal with Fernandes and IIRC they were not playing ball. Now I believe the last video I saw at Sweetwater, didn't he have a Sustainiac in FLO3? and If so, that's why my guess is, it goes into production just like Joe put it in on his guitars. If I'm wrong and it wasn't, then throw my guess out the window.Cool....I have always wondered why the sustainiac was never offered on his Sig. JEM 7V
No, it's still the Fernandes. A black driver, which replaced the white driver after it died years ago. After Sweetwater, Steve went to Starmus festival, I had Flo in my hands tons of times there, it was definitely no sustainiac.Somebody go find that Sweetwater video with FLO3 and see if that wasn't a Sustainiac. It was an afterthought to me a day after i saw it, that is wasn't his regular Fernandes, it had those angular stripped chrome lines on top like a Sustainiac. If he has switched one guitar over, then my guess is it's finally going into production.
I could always and often am, wrong.
