1 - 13 of 13 Posts
Hi there
I've just got back into playing recently and have ordered a JEM JR to add to the collection (the wife would've flipped if I'd gotten a proper one!).
I've seen a few people talk about upgrading the bridge and pickups, so I went digging through my spares collection and found most of the hardware from my old RG plus the neck.
So I have a black trem that just says Ibanez EDGE JAPAN on one side of the trem block and HS on the other side, the locking nut and string guide bar, 6 black GOTOH tuners (no other markings that I can see) and an unmarked humbucker (the poles on one of the coils are flat head screws). If it helps identify those parts, the neck says RG-750 and has serial no F921415.
My question is, are any of these parts worth putting on the JEM JR as an upgrade and would they be a straight swap?
Also, I seem to have misplaced one of the trem posts, where would I look to get a replacement?
Many thanks!
Discussion Starter · #2 ·
Hi there
Many thanks!
After digging around further, I've found the original body and the other pickups so it seems more sensible to rebuild the whole thing and have an extra guitar now. I've had a look at the Ibanez catalogues and it appears to be an 1988/1989 RG750 so will be nice to add it back to the collection!
Definitely a guitar worth restoring to original! What color is it, out of curiosity? Should have come with an F2 pickup bridge pickup made by DiMarzio, which I think sound great.
Discussion Starter · #4 ·
Hi there, thanks for the reply!
Sadly, the original paint is no more (16 y.o. me had no taste), it WAS candy apple red I think. It has the sharkfin inlays with neck and head binding, wasn't one with a pick guard and was HSS. Not sure how best to go about identifying the pickups?
Edge tremolo; should look like this. Lemme know if it doesnt for some reason lol
standard equipment for basically all mij ibbies!
If thats indeed an rg750, your stock pickups would have been an F2 at the bridge and an F4 at the neck; neither of those have flat head poles, so that narrows that down. Further, the "F" pickups will be stamped "MADE IN USA" on the back, as well as having triangle mounting tabs.
Instead, you probably just have a V1/V2 set. I cant think of a good reason why youd have those as well as a 750 neck unless it was some kind of parts guitar situation. Not a huge deal, just wouldnt be much sense in downgrading for no reason.
That neck is a square heel and would be incompatible
they pop up, problem is they use various sizes; we'll have to narrow down the guitar more, or show us some pics.
And YES! Definitely worth putting together lol
Ah, so this would be a 1992 RG760 then. Should have looked something like this...
Yeah, the singles are definitely s1's so I cant think of a good reason why the bridge wouldnt be a V2. Serviceable but not the greatest pickups.
That looks like an edge alright. But to use it in the jem jr I'm afraid you'd have to do some routing. The stud spacing may be off too which would require plugging and redrilling them. The best drop in replacement I've heard for the jr seems to be the gotoh 1996t
If it fits a TRS or lo-trs it'll fit an edge or lo pro just fine. Stud spacing is identical on every floyd rose guitar ever. Its a licensed design. Every floyd rose from the dawn of time, until the heat death of the universe is going to be 74mm stud spacing.
Then if its an edge 3, you need about 12 seconds with a dremel to make it fit. Basically the footprint of the base on the edge/lo pro is like a millimeter too big; takes almost no effort.
Edge pro 2's though? THAT one can take some actual routing. The trem itself will fit just fine, but the problem is the base plate system is offset and you'd need to route move it over to properly fit the replacement tremolo.
Obviously not discussing edge zero systems ofc, thats an entirely different can of worms.
Lol okay, didn't know about the stud spacing - I've only seen the difference when it comes to the edge zero and lo-pro, but different can of worms then as you say. But I really thought switching the trem for an edge or lopro would be a bit more invasive as people warned me about when I was considering a jem jr for upgrading, but I guess not then - might consider doing it myself some time then
I've seen the same "warnings" countless times lol. I've done this a fair amount of times, its not nearly the amount of work I've seen people claim. If you'd like, I've got dimensions of various floyds as well as direct measurements from various bodies I can pm you if youre interested. The lo-trs model ibanez's should basically be a drop in replacement; the lo-trs is bigger lol. The edge 3 is a teeny tiny bit smaller and a bit more contoured, so the body shape matches that which causes the "lack of fit". The edge pro 2 one is irritating because it fits the cavity just fine, but where the block goes doesnt fit at all. THAT SAID, its been a few years, but last time i did that particular upgrade, I realized that part of the guitar is invisible, its a cheap korean ibanez, and no ones gonna care... so I smacked it with a chisel and carved out enough room real fast lol.
Now, in full fairness and full disclosure, despite having done this like a dozen times, I DID encounter an issue once. Im not sure what the deal was; I wish I measured the thing, but I had a korean saber that wouldnt fit an edge because one of the saddle lock bolts was sticking too far out the back and it ran into the body. It was again, like less than a mm, but that IS a very visible and noticeable spot, so youd need to route that for sure. That said, if you lack the skills or equipment to do that, I 100000% promise you you can take that body to a luthier and tell them what you need and they will charge you like 10 bucks for the job.
99.99% of guitars featuring any kind of floyd rose is going to have 74 mm stud spacing with 11mm inserts. REALLY old floyd systems use these studs that actually screw into the body, they are utterly terrible lol; but still, 74mm spacing. I cant think of a single reason why a guitar wouldnt have this spec, but Im giving myself the out for when invariably that one guy comes in "WeLLLLL on my 1982 jackson obscurity, the spacing is SEVENTY SEVEN mm" lol.
edit: Oh yeah, the 1996t is an amazing floyd rose, and a great recommendation regardless of what fits or not.
Sure man, I'd like to see those dimensions if it's cool. Nice to hear the old adage "nothing is impossible" is alive and well, always was confused why it would be that hard
Discussion Starter · #13 ·
Thanks for all the replies - it's been plenty of help!
I received the JEM JR, needed a fair bit of setting up and seems okay but certainly not what I was looking for. Have pre-ordered a JEM7V, so am looking forward to that, especially as it still has an ebony board.
I'm going to rebuild the old RG for nostalgia purposes, needs a little wood work and re-finishing as well as electrics - so will be something good to potter with on rainy weekends.
Thanks again for all the help, and it's been great to find such a trove of information on here :)
1 - 13 of 13 Posts
