1 - 12 of 12 Posts
Hey folks, did u notice the Volume difference between the EVOLUTION pickups and the Single coil in a jem7vwh, imo its completely unbalanced and makes the single coil unusuable, shouldnt they have installed a higher output single to match with the hot evos?
I agree with you, Ralph. While I do like the sound of position 4 (I don't use 2), the middle pup alone is useless. Even if it wasn't for the volume drop, the tone by itself, to me, is flat and dry. I've spent too much money lately, but one day I plan on putting a blue velvet in one of my Jems and see how that goes.
While I agree, too, that the single coils are supposed to have less output, the volume difference could be less dramatic.
Sometimes, depending on the volume of all the other instruments, I can't use the 4th position because I drop out of the mix and can't hear myself.
i've been saying that for years. i actually bought a 7v once upon a time and returned it for that reason.
On the whole, ibanez singles are useless. A hotter dimarzio balances much better and still does the trick for a volume cut/thinning out the sound.
~K
Discussion Starter · #10 ·
do u recomand any dimarzio instead? i still dont understand why ibanez didnt use a hotter pickup!!! the thing is that with paf pro that jem single blended nicely, but there is a hell of a difference between the paf pro and the evolution which should have been taken into account while designing the 7vwh!
The thing with a singlecoil, through a moderately distrted amp is, while output does drop, it's also MUCH less compressed. Back when I had my 7620 (which was wired with a three way and a coil tap, air norton and tone zone), while there was a noticeable volume decrease in the clean channel with the pickups tapped, with my lead settings (Mesa Nomad, 3 vintage, gain about halfway), there was no percieved volume drop on leads simply because the attack was so much mlore explosive, due to the uncompressed nature of a singlecoil sound.
And, for those "in between" sounds, you really need a single coil that balances output-wise with the tapped bridge pickup. A single-coil sized humbucker's definitely an option, provided you wire it to be tapped as well in position 4, or otherwise the sound will be too unbalanced and won't give you that strat "quack."
I set my UV's single-coil height by dialing in the position 4 sound. I don't use the single on it's own very much - personally, i could care less aboput the output, I just think it sounds sterile and compressed for a single - so for me, this is what makes the most sense.
But anyway, that's why they didn't use a hotter pickup - because with even a light amount of gain the amp's compression should effectively even it out, and because a hotter pickup would throw off position 4. ;)
-Drew
1 - 12 of 12 Posts
