Hello all.
I have a 2004 JTK2 , the one with one piece neck and 2 Super 58s.
I had been trouble setting it up, took it 3 times to luthiers to no avail until the 4th found out the neck was twisted. Can't think of a reason why the other hadn't seen it.
Well, the issue is that this JTK neck is almost exclusive to this model which also have the easy access joint, without a backplate.
Scale length is 648mm/ 25½" and radius is 305mmR/ 12".
Has anyone ever replaced the neck of a JTK with one from another non-JTK model ?
Thanks
Thanks
