1 - 14 of 14 Posts
I've got a JPM P1 and a USRG10, both of which I love for different reasons, but the main question i can't get an answer to is.........
Every website i visit says the dimensions of the neck are identical to within 1mm, so why do they feel completely different in thickness when the palm of my hand is wrapped around them?! Am I not getting one dimension that shows how thick they are when you look at them in profile (when you've got it strapped round your neck and you look straight down) because you can see there's an obvious difference.
My other question is whether I could get a JPM neck to fit on my USRG10 without any problems, or is there an RG out there with neck that'll feel like the the JPM in the palm of my hand? (not too bothered with width, it's just it feels chunky like a les paul, ergo comfortable)
I just want THAT neck on my hardtail, H-H configured USRG and I don't know how to do it! (Don't even know what models have been made/are available with a hardtail, apart from the cheapy ones. Not even going there cos I have a definate preference to pickups being screwed INTO the body, not having rings around them; ugly and caused no end of problems on another guitar!)
Any help would be most appreciated as i'm tearing my hair out and have pretty much resolved myself to the fact it can't be done.
Cheers,
Matt
The JPM neck should fit your USRG10 body with no problem.
I think the JPM necks are based off of the Ultra necks. The back of the neck is more rounded than a Wizard or Wizard II. I guess if you want that neck profile on your USRG you could either get another JPM neck, or try and find an AANJ Ultra profile neck. On the home page, check out the necks on the Ibanez and other guitar info link. --Jason
I have a JPM100-P1 (recently acquired) and I read somewhere that the neck profile is called the "viper" profile. Not sure what Ibanez makes these days that is similar to that, but I can tell you that my '04 Jem neck feels pretty damnn close to the JPM in terms of profile.
In fact, to my fingers/hands, the biggest difference I feel between them is the fretwire. The Jem with the 6105 fretwire and the JPM with a slightly wider, but not quite super jumbo fretwire.
BTW, I just had my JPM re-fretted by a master luthier here locally and it is simply awesome. He did such a fantastic job, and matched the original wire size with an impeccable fret end finish over the binding. The guitar itself is in such excellent condition for it's age and the tremolo has little to no bubbling or bumps... this thing is probably about as close to having a brand new one as is possible. ;)
RR
Discussion Starter · #7 ·
If possible i'd like to keep as close to the original look as possible, although i've always liked the Tree of Life inlay, just never been a huge JEM fan. (it's the monkey grip the lions claw behing the trem and the scalloped frets that put me off!)
My neck is a bit of an anomoly in that it's the standard offset markers like the JPM and other USRG's but it's got a bound edge and matching colour headstock, although the guy at PBC said they never made them. Only the translucent purple ones seem to have this cos it was normally restricted to the the USRG30, although it can't be one off of those cos it's got a bone/plastic nut, not a locking nut. The USRG10TP on www.ibanezregister.com is exactly the same.
If JEM neck would feel the same in the flat of my hand, that's a bit more than I knew before.
I didn't have any luck finding any other models that have 24 fret Ultra necks. The closest I found was the Viper profile 24 fret necks that were on the RT series. I'm pretty sure they used the old square neck bolt pattern instead of the AANJ though. If that's the case, they won't do you any good either. --Jason
Discussion Starter · #10 ·
That's partly what's doing my head in cos the dimensions for a wizard II neck look almost identical, but there's a massive difference in feel. However, It doesn't say what the dimensions are for a PBC built USRG, and the tension free neck they built may be radically different to anything else in the ibanez range.
I think the USRG necks were susposed to based off the Wizard Profile. My USRG30 definitely has the feel of an original Wizard, and my USRG10 has a slightly thicker Wizard II feel. Neither of them has a rounded, Ultra feel though. I don't think a Wizard II, or Jem profile, neck is going to give you the chunky, rounded feel that you want. --Jason
I have another suggestion. Why not email or call Bunker Guitars and see if they will make you a new neck? The way those tension free necks are designed, all they would have to do is make a new shell, and just insert your existing headstock/bar assembly. That way you'd have original looks, but with the profile you want. You could even opt for a different fingerboard material or inlay if you wanted a change. (I'd love to have a maple fingerboard with offset abalone dot position markers for my USRG10.) It probably wouldn't be any more expensive than finding an Ultra neck, and possibly cheaper. It would be worth looking into anyway. --Jason
1 - 14 of 14 Posts
