chrisstevenson said:
Hi Rich,
I dont see how chips to the pickup cavities - caused be careless pickup installation, or trems that arnt centrerd in the routed cavity, filler missing from the end of fret slots and faulty volume pots have anything to do with the J craft cases; neck joint cracks 'maybe' - although much less common on the AANJs. I've seen this on many JS, Jem and RG prestige guitars over the past 12 months.
Please enlighten us. How many chips have you seen in pickup cavities?? Were they on Japanese guitars?
Trems have never been "perfectly" centered and it's doubtful they ever will be. Did it being off a hair cause that particular guitar any problems?
Fret end filler is a nice touch that they never used to do, although, it's SUPPOSED to fall out. The neck has to shrink, it is wood.
There isn't a guitar manufacturer in the world that makes their own volume pots. Keep supplier issues in context please.
So what exactly is it you've seen on MANY JS and JEMS in the last year? Be specific.
ric232 said:
Rich, do you mean problems caused during shipment? Or is this a bad case just to store your guitar in?
The case is the only common denominator to the number of NJFC's, and not just JS's, I just sent a BRMR back. This is the way I figure the problem. Every case in the past offered at least some support over the body. The controls pushed into the tops and offered resistence, the trem made good contact, all of which helped stop forward movement of the body. The new J Craft case has absolutely no contact with the top of the guitar at all. There is a cutout the trem and controls sit in, just like the EBMM cases, and look at the NJFC problem the EBMM JPM's have. Uncannily similar situation.
Without any support on the body if the case gets slammed down, or falls, drops, etc on it's face, the body momentum keeps it moving forward. With no contact with the case top there is nothing to resist this movement. The neck is held firmly in place in these cases, which means the neck pocket where the neck is attached is also held firmly. Body moves, neck doesn't, crack. I've started rolling up white styro bags and placing them on top of the body on either side of the neck pickup and behind the trem to make good contact with the top, and bubble wrap the cases of course, all to try and cut down on the cracks.
