1 - 1 of 1 Posts
Hi all,
I just got my first Ibanez! It's a 1996 SF420 made in Korea that will be a new project guitar.
imgur /nJQzY1h
It currently has a Wilkinson/Gotoh wraparound bridge that I wanted to replace with something else for this build. String spacing of the Wilkinson is 1-15/16" (49.21mm) and the other bridges I am looking at have a slightly wider spacing: 2-1/16" (52.4mm).
The neck is a Viper neck, and the specs are below.
Scale length
648mm/25.5"
Width at nut
42mm
Width at last fret
56mm
Thickness at 1st fret
19.5mm
Thickness at 12th fret
21.5mm
Radius
305mmR
So it looks like the slightly wider string spacing should fit the neck just fine, but knowing this information, do you think using the slightly wider spacing would work out just fine for me? It will definitely open up my possibilities as this is a more common measurement. The pole pieces in all of the bridges are the same, so no issues there.
Thank you!
1 - 1 of 1 Posts
