1 - 20 of 22 Posts
It's an RG2550egk, it's awesome except for one thing.... whenever I switch to the middle pickup position I get this annoying buzz. on the 1st and 5th position there's no noise on the 2nd and 4th there's a little noise, on the 3rd it's just annoying... this happens even when my amp's volume is not set out loud at all. Could it be a bad pickup? It's pretty disappointing... it only happens on the middle pickup tho, so anything I can do to fix this?
It's not a bad pickup. Regular single coils tend to buzz, A LOT. This I believe, could be remedied by shielding your guitar (or something like that). Or, you could always get a hum-cancelling single-coil.
Oh, and congrats on the 2550! :D
Discussion Starter · #3 ·
Thanks! I love it but was put off a little by the noise in the middle position... guess I expected everything to be perfect with this guitar... It's my first expensive guitar :) Anyway, so what I'm experiencing is normal for all single coils? Dunno if I'm quite ready to do any tinkering with this guitar... hehehe too scary right now
Congrats dude! It will sound much better if you'll replace the half breed Dimarzio/Ibz pickups with Dimarzios or Seymour. Here's my RG2550EGK now (PAF Pro neck, Screaming Demon bridge)
and my RG1527 i got three weeks ago
mr vai said:
Niece:):) :) :)
What is the differance between a prestige and a j-custom?
J-customs are produced in very, very low numbers, usually around 24 guitars of each model. Since the J-custom line is used mainly to experiment with new and differnt equipment the J-customs can have extra goodies, such as offset dot or J-custom vine inlays, piezos, Dimarzio pickups, very high quality flame or quilt maple tops and experimental finishes. All J-customs also come with a vastly improved AANJ, and have the highest standard in quality in construction, hardware, finishes etc. Although the Prestige lineup is EXTREMELY HIGH QUALITY (my RG1527 and RG1570 are a testiment to that, they are absolutly perfect) the J-customs are one step above that. They are the highest quality guitars ibanez makes, and are well worth the money. I hope to save up enough to buy an RG8527!!
Congrats on the beautiful RG2550 Pablowablo!! its undoubtably an beautiful and fantastic instrument!
I do not think the recent production run of j customs like the 8270 are limited to just 24 pieces. Some of the older j customs (rg-art etc) are very limited, but the "standard" j custom range in Japan are produced in fairly large quantities i believe.
I've had my RG2550 for a little over a month and am loving it!...good thing you took a pic before the pickguard got all marked up....ha, it's nice to have the 'original' look preserved for all time!....I'm beginning to tinker with my bridge, as the high E string is out of tune and the microtuner is bottomed out. This is my first Floyd style trem, so I read up on it and figured I could make this small adjustment...all I'm going to do is loosen the nut screw, turn the microtuner back to around half, and retune the string....bolt down, and carry on from there (probably retune the rest of the guitar)...
BUT, it seems the little kit of allen keys and such don't include a proper fitting allen key for the locking nut!...there's a key in there the looks like an L and has two little pads on it (one says prestige on it) that kinda fits, but very snug. I don't want to risk stripping the tool or the nut...
...any ideas?...and is this the tool for the locking nut, or is that type of allen key so common that they don't include it in the bag of tools with the Prestige?...I just counted and I've got four mini tools in the bag.
Yeah I think you are dead right there. The newer J-Customs are made in larger numbers than 24. I would assume only The Customs such as RG-ART or RG-METAL were made in numbers like 24.
Atarilovesyou: The allen key that fits the locking bolt on the EDGE-Pro is the one that is used for the locking nut. It should be a snug fit, because if it is loose in the hex hole it will strip the bolt head.
1 - 20 of 22 Posts
