1 - 7 of 7 Posts
A few months ago Keri Kelli the lead guitarist for Alice Cooper, had a volume pedal set-up to go from clean to distorted on his amp....Where, it's clean when it's open and distorted when he punches it down. Does anyone have a clue how to do that???
P.S. He says he uses an ernie ball VP JR. if that helps!
You could probably get any volume pedal and skip one of the teeth inside, then when you put it in the down position it isn't really off, and likely pretty clean.
when the volume pedal is in front of the distortion/ od pedals in a chain, it creates the same effect as rolling off your guitars volume knob, and controls the amount of signal going to the gain, so it sounds clean when open but full blast when he opens it up.
hope that helped
1 - 7 of 7 Posts
