1 - 18 of 18 Posts
I have had a few guitars with floyds so i know how to tune and set them up etc. I have owned this guitar about a month. With it in PERFECT tune, if i just pull up the whammy bar then check tuning it is sharp, if i then depress it again it returns to tune.
This says to me the knife edges are worn, is this possible on a guitar that is brand new?? Kinda upset i spent all my money on the guitar i really wanted and it cant even be played properly :(
Please help me fellas!!
Try some lip balm or vaseline on the knife edges. Could just require a slight lube to allow it to return to the zero point freely.
Discussion Starter · #4 ·
Hasnt worked im afraid! It either sits about 1/4 flat or 1/4 sharp unless i ive the trem a little tap in the right direction!!
It's still going to be a setup issue I'd imagine. Go read the tech section at Ibanez Rules (banner at top) and you should be able to work out something for your bridge.
Discussion Starter · #7 ·
Iv read everything on there a million times! I usually set up all my own and friends guitars, this is just a new problem for me. It seems like knife edge wear to me, but i just dont understand how such a new guitar could suffer that!! Is the edge zero 2 a really bad quality trem?
EZ2 has the hardest knives and studs ever. If you've read a million times then you've read no guitar will return 100%, the point is to get it to return close enough to not be noticeable until you dive or bend again.
Discussion Starter · #9 ·
Cheers again Rich! If i put a trem-stopper in so my trem is essentially dive only, and add a bit of spring tension. It should improve its ability to remain in tune. Is this statement correct as far as you know?
LOL! Maybe not cutting through, but roughing up the stud or even putting small nicks to where it hangs up on the stud.
>: D
I guess that sounds plausible. But I don't think that would happen after a month of playing, unless that guitar get passed around for 24 hours a day abusing the whammy bar.
Discussion Starter · #16 ·
I guess iv averaged about an hour a day on it so far. Im not a huge whammy wanker, i tend to just give it a little wiggle now n again ;)
Discussion Starter · #17 ·
Potentially found the problem. I had my bridge set up at a slight upward angle i THOUGHT the edge zero 2 had a wedge shape so i set it to have the baseplate level. Actually after taking the bridge out to check it, it is designed to be set up flush with the body!!!
Discussion Starter · #18 ·
Just thought i would add. I have fitted that little bracket called a 'trem stopper', had to fit it a little differently due to the ergonomics of the edge zero 2. Can safely say its the single best mod i have ever fitted and has changed the feel of my guitar for the better!!!
1 - 18 of 18 Posts
