1 - 3 of 3 Posts
Hoping someone can clarify. I know I could potentially remove the bridge then remove the studs for a look, but I’ve just spent ages setting the thing up after increasing string gauge.
Do the newer 7vs come with locking studs? Mine is a 2019 model. The studs freely move with a 4mm key. I can’t get a 1.5mm (or 2mm) key to engage in anything at the bottom of the studs. No spare grub screws came in the case. Mabye they’ve moved to non-locking studs for the prestige Jems too?
Discussion Starter · #2 ·
Shall answer my own question for anyone googling this in future. Bit the bullet and removed bridge and studs to check. They are indeed locking studs, I think it’s just with the small 1.5mm key I wasn’t getting much feedback to confirm it was engaged.
I search for this problem but couldn't find any such good solution so I not recommend you any irrelevant solutions but I am looking and try to have any solution.
1 - 3 of 3 Posts
