1 - 5 of 5 Posts
hi, i have just found out about an oldish trem, can anyof you help me find anything out about it, i have googled it but no luck.
it says its a
"Product of answer"
"Shift 2001"
"Super bending machine"
its a double locking trem that requires no routing onto the guitar, you bolt it on. i have been very reliably informed that they worked a treat, by someone who used one on a les paul. this would solve my guitar searching problem if i could find something like this to add to a dv8-r.
and are there any other trems that i could look at that would work in a simelar way, just bolt onto the guitar with out routing out needed.
Dave.
As I recall the washburn wonderbar didnt require routing, but wasnt it a single locking tremolo? Ive only messed with one a little bit as I recall it didnt have a lot of range and sounded like pooh
Discussion Starter · #5 ·
i have been told about the washburn elcewhere aswell, it looks good, does the double locking but the range is limited..
the schaller looks good but the guitar i would be fitting it to is a strings thru, i think it needs a tune-o-matic
thanks for your help guys.
1 - 5 of 5 Posts
