1 - 4 of 4 Posts
The time has come for me update my effect pedals. I've fallen in love with the Boss OD 20, and I plan on using that as my main dirty. I'll also be doing some delay and chorus type of effects, both clean and dirty. So I'm looking for a multi effect board that lets me use an external distortion. The only 2 I've seen that can accomodate this are the Boss ME 8 and ME X. Anyone aware of others? Or would I be better off getting some kind multi-way switcher (Morley?)? I don't want to be balancing on my heels trying to hit 3 pedals at once. I've looked at the Boss ME 50, which supposedly has very similar dirty tones to the OD 20, but it didn't sound as good to me.
As long as you can turn the effects and distortions on and off, which you can on almost any mulit-fx pedal then you can use your own distortion pedals. You plug them in the infront of your pedal and you're good to go. My first multi-fx was a digitech rp100 that i got to just play around with some extra effects(plus it was only 30 bucks). I run my ds-1 and sometimes my 250 overdrive in front of it all the time. The pedals help add some nice shape and warmth to the built in distortions as well. I use it both ways just fine. You can do this with about any multi-fx.
Discussion Starter · #3 ·
Yeah, that's what I want to avoid having to do. Say I'm coming out of a dirty part and into a clean part with heavy chorus. I'll have to hit the distortion pedal and the multi board at the same time, which requires careful balancing.
Thanks for chiming in though.
ah, I didn't read your post carefully enough to know how you wanted everything seperate. Perhaps a swticher of some sort would be something to look into.
1 - 4 of 4 Posts
