Status
Not open for further replies.
1 - 7 of 7 Posts
I've got an Ibanez Jem7DBK. I foolishly cut the strings without releasing the tension and the bridge has snapped back and has "sunk" into the body and when I push the trem bar down it kind of moves forwards and "klinks".
What's happened and how do I fix it?
it will klink as the knife edges are making contact with the v groove in the posts, put a block bedind the trem so that the float level is good, then string it back up and you should be fine.
Have you changed string gauge? Have you altered the spring tention at the back of the guitar? Best to double check the bridges knife edges are in good contact with the v groove of the trem posts. Make sure the posts are locked if possible. Also check the knife edges have't moved, as they can be repositioned to the left or right when the trem is off.
1 - 7 of 7 Posts
Status
