1 - 14 of 14 Posts
I love my '88 Jem Rootbeer neck. As I cannot go anywhere close to try out a JS model will I like the Satriani neck profile? How different is it? Can you compare it to any other neck profiles as I have owned and do own quite a few different companies and would like to compare. Is it close to any other Ibanez neck profiles?
thanks
don't know if this is a good description, but I play a Jem7vwh, and when I played the JS1200 and JS1000, the neck to be seems to be a lot rounder, as others have said, its more strat like, I find with the JS series, I get a better grip when bending strings than the Jem.
Administrator
To me it's quite like an older Jem neck but you do notice that it's a thinner nut width quite easily, I've got loads of JSes and none of them have V shaped necks, all are nice and round and smooth.
the old bigger fatter JEM necks are certainly more like the JS necks than they are the modern, skinny super wizards.
I have no problems going between a JEM and a JS :)
It's definitely not a V, and much more round than a Jem (or Wizard, for that matter). I have an RG421 (Wizard II) and the JS is way more strat-ish, though not as thick as the strats I've played.
In summary, I don't think that liking a Jem neck automatically means you'll like a JS neck.
But I have a JS, an RG421 w/ a Wizard II, an SC420 w/ an S-Classic (?) neck, and an RG1527 7 string w/ Prestige Wizard, and I play the best I possibly can, on all necks. Sure, some are better for tapping, others for bending.
But if you're like me, the JS would simply be another tool on your belt, another brush to paint with.
1 - 14 of 14 Posts
