Neck width question (Prestige)
I'm kinda looking into buying a RG652AHMFX, not one closeby to feel how the neck plays unfortunately. So I have 4 Ibanez guitars with 4 types of necks:
EX370FM TR
1 pc. maple Ultra? neck, neck joint, 25.5" scale
Scale length - 648MM/25.5"
Width at nut - 42MM
Width at last fret - 56MM
Thickness at first fret - 19MM
Thickness at 12th fret - 21MM
Radius - 430
JPM 90 HAM
1 pc. maple Viper neck, all-access neck joint, 25.5" scale
Width at nut - 42MM
Thickness at 12th fret - 21.5MM
Radius - 430
RG2820CT TW
3 pc. maple Ultra neck, all-access neck joint, 25.5" scale
Width at nut - 43MM
Thickness at first fret - 19.5MM
Radius - 430
RG 20064
5 pc. Maple/Walnut Prestige neck, all-access neck joint, 25.5" scale
Width at nut - 43MM
Width at last fret - 58MM
Thickness at first fret - 18MM
Thickness at 12th fret - 20MM
Radius - 430
I like the neck of the RG20064 the least and it might be because of the wider neck (58MM) instead of the other 3 that have 56MM necks. The specs of the RG652AHMFX are:
Super Wizard HP5pc Maple/Walnut neck
Scale : 648mm/25.5"
a : Width 43mm at NUT
b : Width 58mm at 24F
c : Thickness 17mm at 1F
d : Thickness 19mm at 12F
Radius : 430mmR
This looks like the default neck for all prestige guitars right now. So what do you guys think, based on my other guitars and preferences, will I like this neck or not? (And yeah I know I gotta feel it for real to make final judgement). Thanks for your advice!
EX370FM TR
Width at nut - 42MM
Radius - 430
JPM 90 HAM
Width at nut - 42MM
Radius - 430
RG2820CT TW
Width at nut - 43MM
Radius - 430
RG 20064
Width at nut - 43MM
Radius - 430
Scale : 648mm/25.5"
Radius : 430mmR
