1 - 13 of 13 Posts
Im looking for new pickups for my S470, I've pretty much decided on a Evo for the bridge, but cant decide what to get for the neck, I was thinking along the lines of a Breed or Air Norton for the neck. My guitar is a H/S/H configuration and I intend to wire it so that when i split the coils both humbuckers work together as oposed to the humbucker and the single.
I play everything from classical to metal, and need something kinda crunchy for the rhythm's something that will stand out for the lead (Evolution..) and something that would work with clean tones also.
Any advice or help would kick ass!
What kind of a metal riff are you going to play in the neck position? Generally you use your neck pickup for lead work and maybe melodies. For metal riffs, you generally want the crunch of the bridge position (for which the Tone Zone would be well suited).
Discussion Starter · #7 · (Edited)
That's intresting, ive been under the impression for the last 1/2 a year that its the other way around.. my horrible powersound pickups i thought just wernt good enough to play any riffs with the neck p.u. (far to bassy).
I figured if i got a good p.u. in there that I could finaly use that for playing something, like hard rock.
So.. it wouldnt work to have a bridge Evo playing leads and riffs from metallica and stuff and having a neck Air Norton or Breed playing cleans and stuff in dropped tuning that needs more of a bass end crunch? Have i got those whole thing backwards?
It says this on the Dimarzio web site... (about evolutions)
Recommended For: Bridge position in solid body guitars.
Tech Talk: The Evolution® bridge pickup works best for soloing where the sound must cut through.
QUOTE]
Okay, you're making this really confusing when it shouldn't be. If it's crunch that you're talking about, then it's going to be your bridge pickup providing that sound simply because that's the way that the strings vibrate right there as opposed to the neck. For METAL rhythm you generally use your bridge pickup (an EVO is fine) but you can also use it for leads. I use my bridge pickup for the fast picking stuff on the first half of the guitar to give it that low end crunch and then I switch to the neck when I go past that so that my notes sound smoother. The neck pickup is well suited for clean stuff, lead work, and some types of rhythm. Of course, these things are all relative and you can use whatever you want to do whatever you want. It's all about what sounds best to you, since it's your guitar.
Discussion Starter · #11 ·
OK, I think I got it, that is actuly what I have been doing from the start. Using the bridge for higher end solos and metal riffs, and neck for cleans and smooth leads.
Judging by what all you have agreed upon, Ill go with the Air Norton=Neck and Evo=Bridge combo.
Thanks for the help!
les paul went to the trouble of writing rhythm and treble on his selector switch. therefore, you must use the neck pickup for rhythm work. and you must stop refering to it as lead work - it's now treble work. ;)
Discussion Starter · #13 ·
Haha, A lot of trouble it must have cost him to put rhythm and treble on his guitars my man! I mean that could have taken a whole 4 mins... lol
1 - 13 of 13 Posts
