1 - 3 of 3 Posts
· Registered
i just had an ibanez given and all the wires are detatched,im not sure what kind of ibanez it is i only have the seria number which is A811883,its a 19 fret,3 single coil pick ups,1 vol,1 tone and one 6 pin toggle switch and a 5 way (vlx51) switch,the pick up wires are white,red and silver braid,
has anyone got a wiring diagram for this or can anyone help me sort it,cheers,neil
i posted this in another section by mistake
· Registered
Hey Neil72,
I just posted a question in my other thread (H-S-H help) about how to wire pick-ups for a 3-wire system. I think I figured out the concept of it. I am waiting for someone to reply to tell me whether or not I have it right. If it is, it will apply to any guitar with 3-wire pups (and 5-wire), and you could use the info to wire yours. You might need to get a multimeter and do some resistance checking on your switch to determine what connectors are hot in each switch position, but that's not difficult.
Good luck,
Trfsrfr
· Registered
Discussion Starter · #3 ·
thanks for the reply mate,iv sinse sorted it,well i think i have it works ok now and sounds great,i have th old style of switch and i think the guitar is a roadstar it has no markings so im not sure what model,its an s-s-s set up with 5 way and 2 way toggle for fade
if anyone needs a diagram ill post one up
trfsrfr-i would still be interested in seeing your diagram when you get it tho so i can compare
1 - 3 of 3 Posts
