1 - 10 of 10 Posts
Well this morning the Fed Ex guy dropped off my new slightly Blemished, Ibanez RG550. I have been working on it since noon and just got finished. It took awhile to find the sweet spot on the trem where I could dive or pull up and have it go back to zero. Polished the frets with some Gorgamyte. The pickups sound great. I set it up Vai style at 1mm on the high E and 1.5 mm on the low E.
This is the lowest action on any of my guitars. It plays super fast.
Now the blemish was a hairline crack in the paint along the low E side of the neck pocket. But for 200 bucks off the 999 dollar price, I am satisfied with it. Set it up with EB Cobalt 9-42 and it sounds great. I actually like the pups that came with it. Good high end, lots of mods, and super tight bass thanks to the Cobalts.
I can pull up a little More than a fourth on it. The case for it came yesterday. Bought used off of Amazon for a hundred bucks.
17542
Looks great, and what a deal! I'll take a routine, hairline crack at the neck pocket for $200 off any day of the week! That's bound to happen eventually anyway. Congrats!
How's this compare to your somewhat similar Jem Jr?
Discussion Starter · #4 ·
The neck on the RG550 is much thinner. It took a few minutes before it didn’t feel strange to me. Yeah that crack at the pocket just reminded me that it is a Strat style guitar. It was either returned for that or else they couldn’t find the sweet spot when setting up the trem. I have mine set up for EB cobalts. 9-42. Yeah the guitar still has warranty, and it’s basically new.
Now I’ve got to get to work on this one.
17544
I wound up cutting five of the slots in the nut, as they were too high. I can see using this for a couple of things, but I don’t think it will be a dail\y player. Glad it was cheap.
Haha, you're on fire, man! I had to turn down the contrast on my screen for the pic. The setup is the hemi-powered Hellcat of guitar.
I guess they're trickling in again. In Europe, they've been out of stock at most places for quite a while; some colours will be back in within a few weeks, apparently.
Discussion Starter · #9 ·
Well, after acclimating for a couple of weeks, the neck on the RG550 moved and I have 2 proud frets. The 6th and 14th frets are causing a buzz and I raised the action to 4/64ths, and it is still there. Added a little more relief to the neck and it didn’t seem to make a difference. I will let it sit for a couple of days and see if it changes. If not, I will take this 2mfrets down a smidge.
Discussion Starter · #10 ·
Well, after acclimating for a couple of weeks, the neck on the RG550 moved and I have 2 proud frets. The 6th and 14th frets are causing a buzz and I raised the action to 4/64ths, If not, I will take this 2mfrets down a smidge.
Well, it turned out that I had to lower just the 6th fret. A couple of passes with the crowning file and neck is adjusted and they are all perfectly level now.
1 - 10 of 10 Posts
