Going back and forth between buying a UV70P and waiting for a UV7BK, I finally found one of the latter and took the plunge. It's possible you've seen this one on ebay (Europe). The previous owner had a replacement neck built by a luthier (Jacaranda) with similar support layering seen in newer necks (including a small volute) as well as an ebony fretboard. Sadly no green dot inlays though (i.e. not a proper greendot). Fret not, I have a NOS replacement neck coming in next week and I'm hoping to restore the guitar as much is possible.
Sadly, other things were also modded that was never disclosed when talking to the seller. It has a 3 way switch with the middle, single coil disconnected (going to fix this). The neck pocket was sanded by the luthier such that the UV stamp was removed... you can see some of that red quality control marker though. He also replaced the strap buttons with some sort of schaller locking type which for some reason required removing some of the finish on the horn? Really strange. All in all, it cost the same as a UV70P in Europe (1777 USD) and about 750 USD less than the latest sold listings I could find in Europe. With the original neck I hope to do a proper setup because the frets would need leveling on the current neck.
