1 - 12 of 12 Posts
A week or two ago, I was talking to a member at Strat-Talk, who lives about 15 miles from me. He had just got a Lawsuit Ibby LP. He also mentioned that he had an Ibanez Studio model up for sale on CL. Well, we worked out a trade, and I met him and we swapped some gear, at my local Mickey D’s. I came home with this…
Musical instrument Guitar Guitar accessory String instrument accessory Wood
Musical instrument Guitar Guitar accessory Wood Musical instrument accessory
I believe it’s an MC50. It is complete with OHSC and all original. It has a 25.5 in (648mm) scale, is 24 frets, and has the original V2’s. The pickup rings are both cracked. Any idea of where I can scoured replacements? They have two screws on the bass side and one on the treble side.. I am going to level and crown the frets, and fill a nasty little chip by the jack input.
I can find a splash of gold in a couple of places on the hardware. I am not going to fix every ding and scratch, just get the main one or two and then buff it up. Just do a light bit of restorative work.
it plays amazingly well. I need to replace the jack, as it’s a little loose and causes static/crackling noises. It’s from 1979. Price for this guitar in 1979 was $199.00. I traded a Mesa Theile 1x12 cab and an SS mini head for it. Cost wise it turned out to be a pretty equal trade.
Excellent find sir!
Repro Guitar Parts stock 3 hole mount pickup rings but currently out of stock i think. They have cream or black ones available, they give you the hole-to-hole measurements so you can determine if they will fit your guitar.
They also sell those toggle switch grommets and switch tips too if you ever need them.
If you wanted to reinstate the gold plating then its a super easy process but its entirely up to you. (y)
Discussion Starter · #3 ·
Excellent find sir!
‘I might try having the gold redone. I am concerned though about the covers on the back of the tuners leaking though. Is that an unfounded fear?
Not an unfounded fear no, obviously you don't want gold plate solution inside the machine heads as it might displace the grease but you don't need to submerge the parts when you plate them.
Basically with the gold plating it gets brushed on. You have something like a cotton bud (q-tip) housed inside a hollow steel rod which has electrical current going to it, because the cotton is wet with gold plating solution it becomes conductive too, you connect the earth cable to the piece that needs to be plated and then brush the gold plate on with the cotton soaked in solution.
If you can imagine negative and positive polarity, you set it up one way, you can attract particles to metal, if you set it up the other way you can remove particles from the metal. I also use my plating kit to remove chrome and take it back to nickel if i need to.
Check out some Youtube videos on the process, it can genuinely be achieved with some 9v batteries and gold plate solution but alot of suppliers do a kit with a voltage regulator, plating solution, brushes etc. Gold plating takes less than 9v so its not a dangerous process, the only real danger is the cyanide in the gold solution.
For reference my plating kit cost me just under $100 and the gold solution makes up half of that price.
Yes indeed, i actually found that out the hard way....
I was plating my stuff and i didn't realise it had cyanide in the solution until my heart started doing backflips :p
The plating process does produce trace amounts of vapour but you don't need a hazmat, just a well ventilated room and a paper mask will do. I basically had my face in it when i done mines because i was excited to watch the process, little did i know i almost killed myself :LOL:
Just do it beside an open window, don't take in a lung full of vapour and you will be fine (y)
Discussion Starter · #7 ·
‘Well my back porch is covered. Is there an concerns on what the temperature is outside?
Back porch will work perfect (y) (y)
Ideally it should be warm so doing it in winter wont work unless you can keep the solution and the part warm during the process. When i done mines i left the item to plate in hot water to let it take on some heat. I also had the bottle of solution in warm water to get some heat in that too.
Solution and plating at average room temps will work however it plates faster when warmed slightly. If you do it outside in winter temps it might not take so well.
Discussion Starter · #9 ·
Sound like I will be waiting until Spring. Thanks for the help.
Discussion Starter · #11 ·
This is a nice score; those old Maxons alone are desirable, and the massive Gibraltar bridge allows for near infinite intonation.
Beefy guitar period for Ibanez - Icemen, Artists, Musicians, Studios, Performers.
I checked t\he sold listings on Reverb, and there were only a handful sold over t\he last couple of years. It was a fair trade, and actually a little in my favor.
1 - 12 of 12 Posts
