I dont have any pix, but wanted to update : Its all done. I used the grinder & took off a 1/4" off the very back of the neck mount heel area (just enuff to have the base plate lay flat against the wood) Then hand sanded to get the flat surface back,making sure to not go past my designated 1/4" mark I also went & got 4 screws that were 1/4" shorter than the originals to make up the difference. Its natural wood with like a varnish type finish thats heavily worn, so what I did visually didnt do much dmage at all Visually. plus its in the back & Im not concerned about resale value very much as its not a highly sought after collectable guitar anyway. Its just a 3rd side project beater that happens to look pretty cool is all with 2 SELECT humbuckers (weakest pups Ive ever heard in my life) .....I locked it down & not that it would help, but couldnt hurt...I dipped the tips of the screws in Wood glue prior to reinserting them. Locked it down, restrung with new strings, to discover one of the trem screws didnt look right ....so remove trem & find the Trem screw post Barrel can be lifted right out. Ugh Not good Luckily I had some spare Trem posts with barrels ...slightly bigger ....Ugh , redrilled holes, installed barrels but they wouldnt sit all the way down like they should, so using a block of wood & light hammer tapping to try & get them down i there tight .....They still wouldnt sit deep enough ...SO pull them back out & redrill 1/8" deeper ....... tapped them in nice & firm ,success....only to find one of the barrels pushed too close to the trem opening ugh,almost fely like now its all ruined. it just barely craked the wood slightly, but still ....so i hit it with wood glue & let it sit overnight....the restrung it, set it up & ignored the small wood crack that the post made & hoped for the best...... so far its doing great. tuned to standard and has a much more comfortable neck joint. so the Mod went fine.
