1 - 4 of 4 Posts
I just installed a Bare Knuckle Apache into my 1977 Fender Musicmaster.
It has be single coil and a volume and tone control.
I want to install a small clean boost to drive a small valve amp into overdrive, so in essence a bit like changing from neck to bridge pu in terms of feel.
It has to be on a push/push pot on either the volume or tone. This is important.
So any ideas where I start? I'm guessing that no one else has done this exactly so there won't be a schematic but any help on the components and layout would be appreciated.
Also, is it possible to do it without using a battery?
Discussion Starter · #2 ·
So no ideas?
How about going active then?
I guess I could install an emg afterburner or pa2 boost then attach that to the push/push to switch it on and off?
You can't boost without a battery. Since you can't add from nothing, you need a battery to add more volts to your signal, always think of batteryless operations as cutting.
So if you want a boost, without a battery, you'll need a high output pickup, then a cut switch. The real trick would be to find a high output single coil pickup that you like the sound of. You'll probably also have to add in a capacitor to retain the high end of the single coil, if one's not built into the knob already.
I believe fender deluxe strats have a volume knob with a button built in under the "volume" label. So maybe you can find that part and a wiring schematic for a place to start?
Discussion Starter · #4 ·
Yep, so not possible. I have the pickup installed that I want and I don't want to go high output for the base tone.
Started looking at the option of using an EMG boost in the on position then attaching that to a push push. Looks doable.
1 - 4 of 4 Posts
