do u no of any sites where i could get an Edge or an Edge Pro?Gilbertoblues said:Yeah, it should. But id have to imagine an Edge or an Edge Pro would fit better(And are much better trems IMO).
What year is your js100, is it pre 2003? If it's got the Lo TRS trem then you can swap it directly with an OFR putting in an Egde or Lo Pro Edge might work but routing maybe needed. Putting in the Edge Pro on the other hand seems to (from want I read) even more diffucult.wastedyears said:Would an Original Floyd Rose trem. fit on my Js100?
yea its 2003... it has a Edge Pro 2...fettouhi said:What year is your js100, is it pre 2003? If it's got the Lo TRS trem then you can swap it directly with an OFR putting in an Egde or Lo Pro Edge might work but routing maybe needed. Putting in the Edge Pro on the other hand seems to (from want I read) even more diffucult.
Regards
André
Then a direct swap with an OFR won't AFAIK. You might want to ask Rich what the option is.wastedyears said:yea its 2003... it has a Edge Pro 2...
Or a Lo-Pro, depending what era it is obviously.wastedyears said:do u no of any sites where i could get an Edge or an Edge Pro?
Yup, well saidPhillip said:On guitar with Edge Pro II you have to do some routing and maybe filling old post holes. Cause Edge Pro will not fit on Edge Pro II guitars, and so Edge or Lo-Pro Edge. The routing and post spacing is different.
Cool, did you checkdex said:The only bridge that would fit an Edge Pro II route is Schaller FRII bridge - all the rest will require some routing.
The posts are spaced and placed exactly where they are on all FR type guitars but the route itself is too small and iregular to accomodate anything else.
ilia
I read somewhere, that new Edge Pro and Edge Pro II have different post spacing than older Ibanez bridges. Even EP II has different spacing than EP.dex said:The only bridge that would fit an Edge Pro II route is Schaller FRII bridge - all the rest will require some routing.
ilia
I agree with this.dex said:Bottom line is the Edge Pro II trem is good enough so save your money and get replacement pickups instead.
