PGM100-neck replacement,which wizard?
1142 Views 1 Reply 2 Participants Last post by  jkahrs
My question is, what kind of neck is originally on a Pgm100?........and the 2nd question is, which wizard necks from which rg or prestige models could i replace the original one with without modification?....THanx in advance.
1 - 2 of 2 Posts
I'm pretty sure the necks on those was the same as what was on the RG7XX series guitars. The only exception would be if the fret size ws different.
If you're just looking for which neck would bolt on, any of the old square heel neck joint 24 fret RG wizard necks will work. An RG7XX series would be closer just because of fingerboard and headstock binding and sharkstooth inlay. Is your original broken or something? --Jason
1 - 2 of 2 Posts
